hello, I’m getting ready to build a boat or two (or 4) and it seems like maslow would be a great way to cut the frames. And the investment is pretty reasonable to get a 4x8 cutting surface.
My question is this: my garage is not tall and I want to cut full 4x8 sheets. So, I think this means:
1 foot below the sheet
4 for the sheet
3+ feet above the sheet and 12’ span to get the optimum full range.
So that means I need 8’ ceilings - which I don’t have, especially with a 12’ span.
What is the largest angle I can put the sled at before friction becomes a problem?
at 30 degrees it comes down to 7’
at 45 degrees it comes down to just over 6’
And as an alternative… If I say I’m just going to use half sheets can I bring it down to 24" over the sheet and maybe an 8 foot span?
you can trim this down to ~9" (even more if you don’t make the sled round)
4 for the sheet
3+ ft is very generous, 2" is probably doing very well
play around with the spreadsheet at
15 degrees is already pushing it, we think that closer to vertical is better.
When designing the new frame, Bar built one with a 20 degree angle
(misunderstanding my directions) and it didn’t work.
see the spreadsheet for the forces of various dimensions.
You can also probably get away with a little less than a foot below the sheet. You, of course, need at least half of your sled diameter so your sled reaches the bottom of the sheet before it hits the ground.
