Disconnect Mid Cut - Upgrade?
My M4 disconnected 3 times in a row. I was manually vacuuming as it went and it nearly finished but disconnected right before its final pass. On the second attempt it didn’t even begin to cut, it disconnected on its way to the start point. The third attempt it made almost one pass before disconnecting.
These were my 3rd, 4th, and 5th attempts at any cut with the machine since assembling it. Is it still likely this is an encoder issue so early on or should I be checking for something else? (my computer isn’t going to sleep I double checked that)
Happy to upgrade if it’s a better setup, just want to make sure it’s the solution to this problem.
And lastly, is there a complete list and/or a guide to upgrading an existing setup? I looked around and didn’t see one, but could have missed it.
Thanks!
Could it be static from the vacuum? We’ve found that with a standard shop vac hose the static can generated can be enough to reset the ESP32.
Thanks for the response! That’s good to know. I’m picking up a hot glue gun to secure the RJ45 connectors after cleaning them out. I will also find a way to ground the shop vac and discharge any static, then report back.
Just to cover bases, I have not updated my yaml file since first assembling the MF and calibrating.
I did update to the latest firmware and index files (v0.87), but the guide vids said updating the yaml would clear the calibration data so I didn’t do that. I don’t know if that could contribute to an error like this.
We found that this anti-static vacuum hose did it for us, but they’re a bit pricy
Tonight I made 4 runs. The Maslow quit 2 times with no error message. I have a copper wire running inside the standard shop vac hose. I haven’t been good about putting the end of the wire in the soil outside (currently frozen) but the wire was resting on the concrete floor… I will be better about grounding in the future. In the meantime, how does this hose work if it isn’t grounded to anything? How do you ground it, if you are using a Home Depot dust collector on a 5 gallon bucket?
Just remembered the first time it quit, I was testing the oil on the z screws. I wasn’t cutting anything so I didn’t have the vacuum connected or the router spinning.
This sounds like static in the dust hose to me. I haven’t played around with adding a ground wire, but I have had good luck using the purpose made anti-static dust hoses.
The easy way to test would be to disconnect the dust hose and run it without the vacuum and see if that fixes the issue.
It failed the first time, no hose, no cutting, no dust.
It failed the second time with a hose and cutting.
It is in my garage, can’t run without the vacuum.
I will try to rig something up with pipe clamps and metal duct connected to ground to make sure there is no static passing from the hose to the router.
Bought the hose, added lots of grounding. Still get random freezes mid cut with no error.
I think someone commented on this before.
If your humidity is very low, then static build up will happen.
If you can get zapped by static getting out of your car, then that level of humidity (or lack thereof) would be sufficient to be problematic.
Are you getting any sort of error message when it happens?
No error message. I ordered a new board on Thursday.
