Hey everyone
I have built my Maslow CNC using the roller chain of 10 mm pitch and triangular linkage of 345mm.
After performing the triangular calibration test
It shows no error in X-axis but Y-axis is very off
For test of 100X100mm
X reaches 100 but Y axis only reach to 90mm only, I’ve tried it to many times but results are same.
After putting values from triangular cutting test
The machine opt chain correction value of 444.738 and linkage radius to 251mm
Please help
Regards
Vikram Singh Rana
IIT KANPUR INDIA. (Manchester of east )
Router bit is absolutely on center.
Linkages are built of aluminum by water jet cutting.
After calibration cutting test my linkage radius change somehow
That seems normal, the calibration process uses the measurements you enter to adjust the linkage radius. How accurate do you think the measurement between the motors is?
A change from 345 mm rotation radius to 251 mm suggests something is misconfigured. You said the chain has a pitch of 10mm… did you adjust the chain pitch in settings? Also, is it a 10-tooth sprocket or something else that you are using? Anything else different (motors, gear ratios, etc.)?
A chainsagcorrection factor for 316.18 (this from the groundcontrol.ini file)… suggest your sled weighs a ton or something went wrong during calibration. Do you recall the measurements you entered for the cuts?
