From the CAM environment within Fusion360:
Make a new ‘Setup’ Folder and begin adding CAM operations (generally from the inside > out with small holes and pockets 1st and contours last)
You’ll want to make sure your CAM operations are sensible, ie: use the simulator a lot, know the limits of the maslow (x/y/z speeds) and those of your router (spindle speeds) and bits (which should be measured, named and numbered, and saved in the Fusion Tool Library, a lot of organization here goes a long way).
Remember that Fusion360 is suitable for MANY completely and utterly different types of CAM operated machines, from heavy duty 2 axis Lathes to 3d printers to building sized 5 axis machining centers and everything in between. I recommend spending a fair amount of time looking through the different options available in each CAM operation until you feel comfortable with what each setting purports to give you control over. Much of it is not terribly important to a machine of MaslowCNC’s ‘accuracy’, but IS for machines that measure their success by 10000’ths of an inch. Spend some time to understand the scale of the numbers in the CAM operations settings.
Taking all this into account, along with observation from both the simulator and in practice on the machine will lead you to begin to save pre-defined settings for each of the major CAM operations (2d pocket, 2d adaptive, and 2d contour are what you’ll be using 99% of the time.)
In each of the CAM operation setting’s tabs, right clicking in an input box will let you save a setting as a preset for that operation, then once an operation is complete and in the Setup Folder on the left, you can right click there and Save that whole operation (sans the contours/paths) as a preset for that type of CAM Operation. eventually you’ll have a list of operations, ex: “MaslowCNC 1/4” 2 Flute Compression Bit 2D Contour", “MaslowCNC 1/8” Hole Drill", etc.
It’s probably a good idea to write out a list of things that need to be done for ‘changing a tool’, ‘adding a tool’, to check before machining’, it’s helped me, and I’m finding that adding a few checks and steps to each process happens with each mistake or unintended error.
Install the maslowCNC Post Processor to your Fusion Post Processor Cloud. I’m not sure why but this is now unavailable on Autodesk’s Post Processor Site, but a search of the forum should give you a link… its around here somewhere.
Once you have the CAM Setup Folder populated with operations, each having been meticulously doted over in the simulator and triple checked for having numbers that make sense, you can right click the Operation and Post Process it.
This is where you would select the MaslowCNC post processor file and save the result as ‘filename.nc’, which is then opened by and run in Ground Control.
hope this helps,
