I’m new here trying to figure out a few things can you only cut sheets of things? Or if I built a ledger board on the top and the bottom so that the router will have a flat surface can I put a piece of oak in between them and route out some oak?
Cutting board lumber using ledger boards is certainly possible. The only caveat is that the Maslow is 2-1/2-dimensional, that is, the third axis is only a short one, so if you are looking to cut through 4"x4"s, you will be disappointed.
Just looking to route out letters and make signs and stuff like that. Not trying to go through. Just wasn’t sure if it could handle hard wood but I guess that would depend on the router
Thanks for the response
thanks for the advice
Did you just screw the table top on the the plywood to hold it up?
Yes screwed from the back side with some deck screws.
If I remember correctly 20ipm 19000 rpm .1inch per pass with a 1/4inch tool
