So I had a thought about two days ago that I have been working on. The Holey Calibration has two squares that look like this:
Point 1 * --- M1 --- * Point 2
| M6 M5 |
M3 X M4
Point 3 * --- M2 --- * Point 4
Now that is actually one more measurement than we need to affix all of those points on an XY coordinate plane.
So I thought, what if I placed all of these points using 5 of the measurements and then calculated the missing distance from these points and compared it to the unused 6th measurement. My thought was if I repeated that 6 times, I could find the most outlier measurement. This could be used to prompt users to check what appears to be the worst measurement.
Except, I don’t think it works … I think my premise is wrong.
Sadly, I built all of the work already, it was at least a good refresher on deriving geometric functions again (Law of Cosines, Intersecting points on two circles).
The results I get look like this:
{'M1': -4.769083263379116,
'M2': -4.768156399617851,
'M3': -6.492332606734294,
'M4': -6.444498656751762,
'M5': 3.840564042951428,
'M6': 3.8360705815812253}
Where the number reported is the measured distance - the distance derived from plotting the points using the other measurements.
What I think I discovered, is that even if it is only one bad measurement (and it never is) I can’t discern which is bad. If the bad measurement is included, then the error calculations of all of the other measurements look bad. And when the bad measurement isn’t included, its error calculation is high because, well it is an error.
Anyways, is there something I am missing? Could one actually learn anything from doing these calculations.
Also, my errors seem very odd to me. It is entirely possible I have made some math mistake. Related lines all look very similar to each other. Plus the error amount which should be in mm seems way too high. I could be off my a mm on some measurements at worst, but I would be surprised if it averaged to even that high.
