After taking 12 precise triple-checked measurements in mm, i realized that they are entered in inch.
Can someone please decode this for me ( RunHoleyCalibration.py line 25)
(47.+5./8.)-(9.+11./16.)
It is a measurement in inches. It is the 2nd position on the tape, minus the 1st.
Also, today, I just finished some work debugging the GUI update. I was able to go through the calibration within the GUI. You might want to give that a try. It is in a different repository.
I’m not well versed in github and I’m trying to understand what “base” code (“tree”?) you used for each repository. I looked through the readme files but didn’t see anything pertaining to where the code was forked from, although I’m probably looking in the wrong place. This latest GUI work; what “version” FW and GC was it built off of?
I appreciate your time and good work.
Ok, think I got it. So entering a number like 38.0315 (966mm in inch) would also work, right?
confirming that these are still the latest instructions Holey Triangular Calibration
could you edit the first post and put a link to them? (and then update the link if the instructions change)
There is quite a bit of information I haven’t provided. I will do my best.
This was confusing for me, as well. So, when I originally created the Ground Control and Firmware branches, I did something wrong; they were not real forks in GitHub. Because of this mistake, when I tried to create a test pull-request, I couldn’t. To correct this, I had to go through this whole thing, where I re-forked (correctly, this time) GC and the Firmware, and then merged from my incorrectly forked repos, into the correctly forked repos.
Yeah. It is just the measurement. It is a list of measurements, 1 through 12.
Yeah. I can do this, at some point. However, (tagging @Gero so he reads it) I realized the home position dropped significantly (1500 mm) when I finished the (new version of the) calibration process. So, there may still be an issue that needs to be resolved. This is just an FYI.
Looks like i got good calibrated for my first attempt.
Edit 1:
wait for edit 2
“Do not drink and script!” - Linus Torvalds
Right. That is a good observation. The 12th one is different because it is measured to the top of the work piece. The top of the work piece does not have a hole number. That measurement is done after, on the Measurements.append(… line, that is after the loop.
I was on the wrong py-script
Optimized Errors
Index : 0
Points Span : 1 to 2
Measured Distance : 966.0001
Calibrated Distance: 932.782509423
Distance Error : 33.2175905772
Index : 1
Points Span : 2 to 3
Measured Distance : 964.99934
Calibrated Distance: 973.454454822
Distance Error : -8.45511482166
Index : 2
Points Span : 4 to 5
Measured Distance : 964.00112
Calibrated Distance: 932.528364597
Distance Error : 31.4727554027
Index : 3
Points Span : 5 to 6
Measured Distance : 963.00036
Calibrated Distance: 970.275709594
Distance Error : -7.27534959424
Index : 4
Points Span : 1 to 4
Calibrated Distance: 805.511920922
Distance Error : 158.489199078
Index : 5
Points Span : 2 to 5
Measured Distance : 710.00112
Calibrated Distance: 772.134944167
Distance Error : -62.1338241667
Index : 6
Points Span : 3 to 6
Calibrated Distance: 710.276626635
Distance Error : -0.275506634913
Index : 7
Points Span : 2 to 4
Measured Distance : 1197.0004
Calibrated Distance: 1192.07081007
Distance Error : 4.9295899298
Index : 8
Points Span : 1 to 5
Measured Distance : 1200.00014
Calibrated Distance: 1250.03420628
Distance Error : -50.0340662797
Index : 9
Points Span : 3 to 5
Measured Distance : 1197.99862
Calibrated Distance: 1165.37957551
Distance Error : 32.6190444899
Index : 10
Points Span : 2 to 6
Measured Distance : 1195.63896
Calibrated Distance: 1275.84908375
Distance Error : -80.2101237466
Distance Between Motors:
3621.28354785
Motor Y Offset:
431.936559116
Left Chain Tolerance:
4.5884952892
Right Chain Tolerance:
-2.77555229331
Something wrong here, will try fresh ![]()
Yeah. Something seems off.
Fixed it and it worked! Thanks so much. Cutting need to wait
Observations for the GUI version:
motorspacingx = 3495.27578505
motoroffsety = 531.923557145
triggers
Message: Unable to find valid machine position for chain lengths 2032.00, 2032.00 . Please set the chains to a known length (Actions → Set Chain Lengths)
Solved by setting:
motorspacingx = 3495.28
error report for an image in the terminal when reaching this page
strange images and no descriptive text (thank for the metric, a hint would be nice, although turns red when trying inch) on this page
I can see in the repo, in GitHub, that image is present. I am trying to think of some potential root-causes.
This one is consistent with what I get much of the time. I am pretty sure I know the root-cause. I it is because the _verifyValidTarget doesn’t let a kinematics::forward result in a number that is off the board. Once all the calibration parameters are written to the Arduino, this error goes away. I propose we bypass the _verifyValidTarget diagnostics step when doing the kinematics::forward calculation. What are your thoughts about that?
I was unaware of this. I would like to check if this works for me, too.
Yeah. That one needs to be fixed.
I had to create a new fork, to enable the eventual pull-request.
In terms of the GUI implementation, the most up-to-date one is here (Note the missing “Update”. Not GroundControlUpdate):
I believe to have done 2 (GUI / non-GUI) out of 3?
I am reading incredible results in the Forum and always behind, but think it deserves:
I have been working on this for a while, and I thought an update is in order.
@jimr had some difficulty when he tried to do this, where he got the message “Please reset the chain-lengths”. I was able re-produce this issue, and came up with a multitude of potential root-causes.
I believe I have fixed these two.
I have not yet fixed this one.
I’m looking to use the WebControl interface, is it possible to use this with the
holey triangular firmware? (assuming I use the external program to do the
calibration)?
That is a question to ask @madgrizzle. I have attempted to write this in such a way that it can be easily ported over to a different GUI; I minimized the amount of content that is specific to Kivy. So, the only content that needs to be reproduced is the GUI part.
I think so. I don’t think @madgrizzle has changed the Firmware. We’d have to check. The changes I have made should merge into any branch, as long as they are not too different.
yeah. this is always an option. Even without a GUI, you can use the script to run the calibration.
Webcontrol can be made to work with whatever. It supports stock firmware as well as mine with optical calibration support. Im confident it can be made to work with holey calibration firmware.
