How I achieved calibration finally
I have had the same endless loop problems many others have experienced. I have a non standard size frame laying horizontally on the ground. I hate changing more than one thing at a time - not knowing what actually solved the problem. However I did and here are the last set of changes I made which solved the problem.
  1. I did go back and clip the leads to the encoder boards. Mine were 0.075 inches to begin and under 0.040 afterwards. It is a pain to disassemble/reassemble.
  2. I measured my frame and manually entered the values in through FluidNC. Note: I made anchors that matched the height of the 4 cables - therefore I entered 0 for all 4 Z heights. And saved the values ( I think you need to go back to top to make sure it’s fully saved)
    My “extend all” distance was within 1/2” of minimum necessary. I did pull sled down - tightening the to and tr belts.
    Within 10 seconds of starting the fitness calibration calculations I knew this was going to be different. It still took several minutes (probably 5) but numbers were quickly over 1.0 on fitness.
    I hope this helps others.
This is very helpful - can you expand on #1 - what do you mean by clip the leads to the encoder boards?
I’m not home so I can’t send a picture. The back side of the encoder board where the connector wires come through were very close to the bearings and possibly touching. To eliminate any possibility of touching/shorting I clipped them shorter leaving a visible gap. To get at those wire ends I believe you have to disassemble.
Hope this helps
Karl
