Got the belt untangled, and can’t see any damage.
Shortened all belts, so they fit on the spools.
Retract and extend now seem to function much better.
Initial fitness seems much higher but drops rapidly with the 2nd and 3rd iterations.
Calibration ultimately fails every time.
Serial Messages
[MSG:INFO: FluidNC v0.76 (Maslow-Main-67a72cf4-dirty)]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Config messages ran]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Internet]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.4.92]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Bottom Right pulled tight with offset -1112.817]
[MSG:INFO: Top Right pulled tight with offset -1684.996]
[MSG:INFO: Bottom Left pulled tight with offset -2433.215]
[MSG:INFO: Top Left pulled tight with offset -2752.206]
[MSG:INFO: Zeroing z-axis position]
[MSG:INFO: Center point deviation: TL: 0.137 TR: 0.207 BL: 1.423 BR: -9.371]
CLBM:[{bl:2067.31, br:2061.66, tr:2073.81, tl:2071.35},{bl:1996.83, br:2002.21, tr:2143.89, tl:2139.66},{bl:1790.25, br:2213.13, tr:2346.30, tl:1953.94},{bl:1862.84, br:2275.69, tr:2282.83, tl:1872.43},{bl:1944.35, br:2342.26, tr:2220.26, tl:1795.88},{bl:2138.73, br:2145.24, tr:2004.66, tl:1993.93},{bl:2341.14, br:1953.64, tr:1797.95, tl:2210.84},{bl:2275.18, br:1872.04, tr:1871.02, tl:2276.74},{bl:2212.52, br:1795.47, tr:1953.27, tl:2343.32},]
Computing… This may take several minutesFitness: 0.9428762 in 100
Fitness: 0.9818487 in 200
Fitness: 0.9818487 in 300
Fitness: 0.9818487 in 400
Fitness: 0.9818487 in 500
Fitness: 0.9818487 in 600
Fitness: 0.9818487 in 700
Fitness: 0.9818487 in 800
Fitness: 0.9818487 in 900
Fitness: 0.9818487 in 1000
Fitness: 0.9818487 in 1100
Calibration complete
Calibration values:
Fitness: 0.9818486619710081
Maslow_tlX: 2.6
Maslow_tlY: 2379.3
Maslow_trX: 3388.2
Maslow_trY: 2374.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3386.3
Maslow_brY: 0.0
A command to save these values has been successfully sent for you. Please check for any error messages.
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
CLBM:[{bl:2067.31, br:2061.66, tr:2073.81, tl:2071.35},{bl:1996.83, br:2002.21, tr:2143.89, tl:2139.66},{bl:1790.25, br:2213.13, tr:2346.30, tl:1953.94},{bl:1862.84, br:2275.69, tr:2282.83, tl:1872.43},{bl:1944.35, br:2342.26, tr:2220.26, tl:1795.88},{bl:2138.73, br:2145.24, tr:2004.66, tl:1993.93},{bl:2341.14, br:1953.64, tr:1797.95, tl:2210.84},{bl:2275.18, br:1872.04, tr:1871.02, tl:2276.74},{bl:2212.52, br:1795.47, tr:1953.27, tl:2343.32},{bl:2161.01, br:1721.00, tr:2034.96, tl:2418.06},{bl:1939.04, br:1932.76, tr:2216.57, tl:2225.93},{bl:1724.57, br:2154.66, tr:2412.67, tl:2042.17},{bl:1521.06, br:2382.47, tr:2615.69, tl:1873.84},{bl:1599.95, br:2434.77, tr:2554.61, tl:1779.54},{bl:1687.25, br:2489.99, tr:2492.84, tl:1689.25},{bl:1779.49, br:2549.06, tr:2435.84, tl:1603.58},{bl:1874.46, br:2615.49, tr:2384.11, tl:1523.39},{bl:2039.60, br:2416.53, tr:2156.62, tl:1725.10},{bl:2220.92, br:2220.79, tr:1934.56, tl:1941.76},{bl:2417.18, br:2037.01, tr:1720.16, tl:2164.49},{bl:2623.25, br:1868.70, tr:1516.72, tl:2392.28},{bl:2559.16, br:1774.38, tr:1600.34, tl:2440.25},{bl:2497.32, br:1683.94, tr:1686.63, tl:2496.81},{bl:2440.35, br:1598.24, tr:1776.72, tl:2557.61},{bl:2388.53, br:1518.01, tr:1871.41, tl:2620.72},]
Computing… This may take several minutesFitness: 0.5216692 in 100
Fitness: 0.5245484 in 200
Fitness: 0.5245484 in 300
Fitness: 0.5245484 in 400
Fitness: 0.5245484 in 500
Fitness: 0.5245484 in 600
Fitness: 0.5245484 in 700
Fitness: 0.5245484 in 800
Fitness: 0.5245484 in 900
Fitness: 0.5245484 in 1000
Fitness: 0.5245484 in 1100
Calibration values:
Fitness: 0.5245483926840606
Maslow_tlX: -4.1
Maslow_tlY: 2372.1
Maslow_trX: 3386.7
Maslow_trY: 2378.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3386.6
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Measured waypoint 48]
CLBM:[{bl:2067.31, br:2061.66, tr:2073.81, tl:2071.35},{bl:1996.83, br:2002.21, tr:2143.89, tl:2139.66},{bl:1790.25, br:2213.13, tr:2346.30, tl:1953.94},{bl:1862.84, br:2275.69, tr:2282.83, tl:1872.43},{bl:1944.35, br:2342.26, tr:2220.26, tl:1795.88},{bl:2138.73, br:2145.24, tr:2004.66, tl:1993.93},{bl:2341.14, br:1953.64, tr:1797.95, tl:2210.84},{bl:2275.18, br:1872.04, tr:1871.02, tl:2276.74},{bl:2212.52, br:1795.47, tr:1953.27, tl:2343.32},{bl:2161.01, br:1721.00, tr:2034.96, tl:2418.06},{bl:1939.04, br:1932.76, tr:2216.57, tl:2225.93},{bl:1724.57, br:2154.66, tr:2412.67, tl:2042.17},{bl:1521.06, br:2382.47, tr:2615.69, tl:1873.84},{bl:1599.95, br:2434.77, tr:2554.61, tl:1779.54},{bl:1687.25, br:2489.99, tr:2492.84, tl:1689.25},{bl:1779.49, br:2549.06, tr:2435.84, tl:1603.58},{bl:1874.46, br:2615.49, tr:2384.11, tl:1523.39},{bl:2039.60, br:2416.53, tr:2156.62, tl:1725.10},{bl:2220.92, br:2220.79, tr:1934.56, tl:1941.76},{bl:2417.18, br:2037.01, tr:1720.16, tl:2164.49},{bl:2623.25, br:1868.70, tr:1516.72, tl:2392.28},{bl:2559.16, br:1774.38, tr:1600.34, tl:2440.25},{bl:2497.32, br:1683.94, tr:1686.63, tl:2496.81},{bl:2440.35, br:1598.24, tr:1776.72, tl:2557.61},{bl:2388.53, br:1518.01, tr:1871.41, tl:2620.72},{bl:2336.05, br:1448.49, tr:1976.32, tl:2686.32},{bl:2103.64, br:1658.97, tr:2131.14, tl:2494.84},{bl:1875.62, br:1882.84, tr:2304.18, tl:2305.31},{bl:1653.80, br:2112.94, tr:2491.98, tl:2128.39},{bl:1441.37, br:2346.89, tr:2691.72, tl:1967.38},{bl:1242.94, br:2583.58, tr:2898.65, tl:1826.57},{bl:1331.49, br:2622.60, tr:2840.26, tl:1721.03},{bl:1423.16, br:2666.67, tr:2778.93, tl:1618.33},{bl:1518.82, br:2716.82, tr:2721.92, tl:1518.91},{bl:1619.08, br:2772.70, tr:2669.58, tl:1423.54},{bl:1722.59, br:2831.82, tr:2622.15, tl:1333.07},{bl:1828.45, br:2895.08, tr:2579.96, tl:1248.68},{bl:1967.97, br:2696.37, tr:2344.23, tl:1448.64},{bl:2122.73, br:2496.92, tr:2111.96, tl:1659.72},{bl:2297.52, br:2307.32, tr:1884.06, tl:1879.77},{bl:2484.97, br:2130.26, tr:1662.44, tl:2109.06},{bl:2684.63, br:1969.08, tr:1450.12, tl:2342.76},{bl:2895.11, br:1828.10, tr:1251.71, tl:2581.12},{bl:2831.89, br:1722.55, tr:1340.63, tl:2619.29},{bl:2770.58, br:1619.76, tr:1431.89, tl:2665.35},{bl:2713.65, br:1520.26, tr:1527.63, tl:2716.74},{bl:2661.38, br:1424.98, tr:1627.68, tl:2770.62},{bl:2614.09, br:1334.46, tr:1731.05, tl:2830.52},{bl:2571.91, br:1249.88, tr:1836.14, tl:2894.03},]
Computing… This may take several minutesFitness: 0.3446611 in 100
Fitness: 0.3446611 in 200
Fitness: 0.3446611 in 300
Fitness: 0.3446611 in 400
Fitness: 0.3446611 in 500
Fitness: 0.3446611 in 600
Fitness: 0.3446611 in 700
Fitness: 0.3446611 in 800
Fitness: 0.3446611 in 900
Fitness: 0.3446611 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
