After 2 failed attempts, I succeeded at completing a test cut today. But the accuracy was not good. I made (4) 152.4 mm circles out of 1/2" plywood. They came out oval. They were 153mm in the X direction and 147mm in the Y direction. I stacked them on top of each other and they were all within .5mm of being identical to each other. So, I assume that my Y calibration is off. They were also oval on the 2 failed attempts and were off by about the same 6mm.
Each time, I ran a calibration immediately prior to doing the cut (because I had other issues that I was hoping to fix). So there is consistency in the calibration. The only visible issue that I noticed was that when the cutting finished, the belt has risen up almost 2" on the bolt at the bottom right anchor, the top left rose 3/8" and the other 2 did not rise. These are 3/8" bolts screwed into concrete expansion anchors with a plastic spacer to raise it up 2" to match my spoil board.
I am using horizontal orientation and my anchors are 9’-10" x 12’-2". My calibration settings were 500mm x 500mm with 3X3 and 1300 retraction and calibration tension. This Maslow runs a calibration quickly and consistently with firmware 1.13 but it does not remember the belt length when I detach it from the anchors and it gets stuck in the “extend” then “retract” loop a lot before it will finally calibrate. And I can never get the belts to extend when the machine is anchored no matter how hard I pull and rock, even with the retraction tension set to 100. It needs to have all the tension relieved and then the belts extend easily. Is that the way it is supposed to be? I’m new here.
What should I try next to get these ovals to be circles? A bigger calibration size? Here is my Serial File:Serial Messages
Index.html Version: v1.13
[MSG:INFO: FluidNC v1.13 (Maslow-Main-13c33c4c)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:EPBNetwork2]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: No SSID]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
Grbl 1.13 [FluidNC v1.13 (Maslow-Main-13c33c4c) (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:INFO: Center coordinates updated in MaslowKinematics: X=1869.110]
[MSG:INFO: Motor1]
[MSG:INFO: No SSID]
[MSG:INFO: WiFi on]
[MSG:INFO: Center coordinates updated in MaslowKinematics: X=1869.[MSG:INFO: loadBeltPositions() called]
[MSG:INFO: Validity check: ret=0 validityMarker=0]
[MSG:INFO: Saved belt positions in NVS are marked as stale/invalid (value=0) - machine will remain in UNKNOWN state until belts are calibrated/extended]
[MSG:INFO: Starting Maslow Version v1.13-6-g13c33c4c]
[MSG:INFO: Caution: Unlocked]
Test
[MSG:INFO: Firmware Version: v1.13-6-g13c33c4c]
[MSG:INFO: I2C Timeout: ]
[MSG:INFO: 10]
[MSG:INFO: All tests passed on Top Left]
[MSG:INFO: All tests passed on Top Right]
[MSG:INFO: All tests passed on Bottom Left]
[MSG:INFO: All tests passed on Bottom Right]
Extend All
[MSG:INFO: Requesting state change from Unknown to Extending Belts]
[MSG:INFO: Cannot extend the belts until they have been retracted]
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Bottom Left pulled tight with offset -1861.701]
[MSG:INFO: Top Right pulled tight with offset -1885.954]
[MSG:INFO: Bottom Right pulled tight with offset -1955.342]
[MSG:INFO: Top Left pulled tight with offset -1842.720]
Calibrate
[MSG:INFO: Requesting state change from Belts Retracted to Calibrating]
[MSG:INFO: Cannot start calibration until the belts have been extended]
Extend All
[MSG:INFO: Center coordinates updated in MaslowKinematics: X=1869.590 Y=1463.819]
Extend All
[MSG:INFO: Requesting state change from Extending Belts to Extending Belts]
Extend All
Apply Tension
[MSG:INFO: Requesting state change from Extending Belts to Taking Slack]
[MSG:INFO: Cannot take slack until the belts have been extended]
Extend All
Retract All
[MSG:INFO: Requesting state change from Extending Belts to Retracting Belts]
[MSG:INFO: Bottom Left pulled tight with offset -528.001]
[MSG:INFO: Top Left pulled tight with offset -496.662]
[MSG:INFO: Bottom Right pulled tight with offset -2004.545]
[MSG:INFO: Top Right pulled tight with offset -2038.825]
Retract All
[MSG:INFO: Requesting state change from Belts Retracted to Retracting Belts]
[MSG:INFO: Bottom Right pulled tight with offset 0.032]
[MSG:INFO: Top Right pulled tight with offset 0.000]
[MSG:INFO: Bottom Left pulled tight with offset -1892.782]
[MSG:INFO: Top Left pulled tight with offset -1943.918]
Extend All
[MSG:INFO: All belts extended to 2400.000mm]
Extend All
[MSG:INFO: Requesting state change from Belts Extended to Extending Belts]
[MSG:INFO: All belts extended to 2450.000mm]
Calibrate
[MSG:INFO: Requesting state change from Belts Extended to Calibrating]
[MSG:INFO: Calibration starting in HORIZONTAL orientation mode]
[MSG:INFO: Machine Position found as X: 18.976 Y: -374.169]
[MSG:INFO: Setting motor positions from hardware readings:]
[MSG:INFO: TL: 2464.887 TR: 2463.963 BL: 2463.985 BR: 2466.143]
[MSG:INFO: Center point off by: TL: 0.000 TR: 0.000 BL: -5.276 BR: -9.235]
[MSG:INFO: Machine Position computed as X: 7.249 Y: -8.356]
[MSG:INFO: Requesting state change from Calibrating to Calibration Computing]
CLBM:[{bl:2369.82, br:2368.80, tr:2382.48, tl:2367.34},{bl:2485.60, br:2266.37, tr:2272.19, tl:2474.81},{bl:2577.30, br:2349.08, tr:2176.42, tl:2407.05},{bl:2475.25, br:2459.38, tr:2283.16, tl:2284.37},{bl:2362.99, br:2574.96, tr:2406.22, tl:2162.61},{bl:2262.97, br:2502.24, tr:2492.49, tl:2241.55},]
Computing… This may take several minutesInitial guess fitness: 0.2226311
Frame dimensions: 3738.4mm x 2908.0mm (aspect ratio: 1.29:1)
Initial fitness >= 0.1 and frame is not square, skipping rectangular optimization and using initial guess directly.
Fitness: 1.1740033 in 100
Fitness: 1.1828775 in 200
Fitness: 1.2034412 in 300
Fitness: 1.2034412 in 400
Fitness: 1.2034412 in 500
Fitness: 1.2034412 in 600
Fitness: 1.2034412 in 700
Fitness: 1.2034412 in 800
Fitness: 1.2034412 in 900
Fitness: 1.2034412 in 1000
Fitness: 1.2034412 in 1100
Fitness: 1.2034412 in 1200
Calibration values:
Fitness: 1.203441264364275
Maslow_tlX: 11.7
Maslow_tlY: 2912.9
Maslow_trX: 3741.2
Maslow_trY: 2932.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3748.9
Maslow_brY: 0.0
A command to save these values has been successfully sent for you. Please check for any error messages.
Calibrate
[MSG:INFO: Requesting state change from Calibration Computing to Calibrating]
[MSG:INFO: Machine Position found as X: -146.291 Y: 1.665]
[MSG:INFO: TL: 2090.552 TR: 2341.959 BL: 2110.660 BR: 2350.161]
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
CLBM:[{bl:2369.82, br:2368.80, tr:2382.48, tl:2367.34},{bl:2485.60, br:2266.37, tr:2272.19, tl:2474.81},{bl:2577.30, br:2349.08, tr:2176.42, tl:2407.05},{bl:2475.25, br:2459.38, tr:2283.16, tl:2284.37},{bl:2362.99, br:2574.96, tr:2406.22, tl:2162.61},{bl:2262.97, br:2502.24, tr:2492.49, tl:2241.55},{bl:2370.08, br:2388.10, tr:2384.84, tl:2351.46},{bl:2233.02, br:2241.23, tr:2534.07, tl:2513.52},{bl:2029.83, br:2445.36, tr:2721.15, tl:2344.37},{bl:2179.56, br:2580.95, tr:2584.70, tl:2169.71},{bl:2352.74, br:2729.18, tr:2450.44, tl:2010.41},{bl:2530.27, br:2549.05, tr:2239.67, tl:2206.02},{bl:2720.88, br:2370.05, tr:2034.58, tl:2419.51},{bl:2580.16, br:2195.37, tr:2183.98, tl:2554.64},{bl:2446.36, br:2036.37, tr:2355.54, tl:2703.47},]
Computing… This may take several minutesInitial guess fitness: 1.0456351
Frame dimensions: 3729.5mm x 2912.9mm (aspect ratio: 1.28:1)
Fitness: 1.1540774 in 100
Fitness: 1.1833064 in 200
Fitness: 1.1836694 in 300
Fitness: 1.1836694 in 400
Fitness: 1.1836694 in 500
Fitness: 1.1836694 in 600
Fitness: 1.1836694 in 700
Fitness: 1.1836694 in 800
Fitness: 1.1836694 in 900
Fitness: 1.1836694 in 1000
Fitness: 1.1836694 in 1100
Fitness: 1.1836694 in 1200
Calibration values:
Fitness: 1.183669386936196
Maslow_tlX: 12.6
Maslow_tlY: 2914.1
Maslow_trX: 3744.1
Maslow_trY: 2928.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3749.7
Maslow_brY: 0.0
Calibrate
[MSG:INFO: Machine Position found as X: 250.892 Y: -242.525]
[MSG:INFO: TL: 2552.031 TR: 2203.012 BL: 2293.271 BR: 1884.741]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
CLBM:[{bl:2369.82, br:2368.80, tr:2382.48, tl:2367.34},{bl:2485.60, br:2266.37, tr:2272.19, tl:2474.81},{bl:2577.30, br:2349.08, tr:2176.42, tl:2407.05},{bl:2475.25, br:2459.38, tr:2283.16, tl:2284.37},{bl:2362.99, br:2574.96, tr:2406.22, tl:2162.61},{bl:2262.97, br:2502.24, tr:2492.49, tl:2241.55},{bl:2370.08, br:2388.10, tr:2384.84, tl:2351.46},{bl:2233.02, br:2241.23, tr:2534.07, tl:2513.52},{bl:2029.83, br:2445.36, tr:2721.15, tl:2344.37},{bl:2179.56, br:2580.95, tr:2584.70, tl:2169.71},{bl:2352.74, br:2729.18, tr:2450.44, tl:2010.41},{bl:2530.27, br:2549.05, tr:2239.67, tl:2206.02},{bl:2720.88, br:2370.05, tr:2034.58, tl:2419.51},{bl:2580.16, br:2195.37, tr:2183.98, tl:2554.64},{bl:2446.36, br:2036.37, tr:2355.54, tl:2703.47},{bl:2235.24, br:2231.97, tr:2532.66, tl:2523.08},{bl:2370.91, br:2379.19, tr:2383.42, tl:2360.96},]
Computing… This may take several minutesInitial guess fitness: 1.1572267
Frame dimensions: 3731.5mm x 2914.1mm (aspect ratio: 1.28:1)
Fitness: 1.1746440 in 100
Fitness: 1.1746440 in 200
Fitness: 1.1746440 in 300
Fitness: 1.1746440 in 400
Fitness: 1.1746440 in 500
Fitness: 1.1746440 in 600
Fitness: 1.1746440 in 700
Fitness: 1.1746440 in 800
Fitness: 1.1746440 in 900
Fitness: 1.1746440 in 1000
Calibration values:
Fitness: 1.1746439477997626
Maslow_tlX: 12.7
Maslow_tlY: 2914.1
Maslow_trX: 3744.9
Maslow_trY: 2927.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3749.9
Maslow_brY: 0.0
Calibrate
[MSG:INFO: Machine Position found as X: -0.008 Y: -7.851]
[MSG:INFO: TL: 2209.830 TR: 2230.797 BL: 2217.774 BR: 2227.190]
[MSG:INFO: Calibration state reset]
[MSG:INFO: Requesting state change from Calibrating to Ready To Cut]
