Installing firmware via usb
So after installing an update, I’m no longer able to connect to the maslow wifi or via the router.
I have tried to reset things via usb, and when running the “Full-Install.command” I get an error
" bad interpreter: No such file or directory
esptool failed"
after seeing a similar issue someone suggested to downloaded Python Launcher and run
“python3 -m pip install esptool” (which I did in the Terminal thing)
however this didn’t help…
has anyone else defeated the “esptool failed” boss?
or have suggestions?
I’m running a mac
I have tried three usb cables (that work with data)
turning off and on each try, and while holding the reset button.
esptool failed"
on linux I manually installed esptool (ended up with esptool.py IIRC
