Firmware upgrade fail
I just got my Maslow assembled and working through the set up process. I followed the instructions to update firmware. I uploaded firmware.bin and then the machine disconnected and would not connect again. I could not make any further progress so I decided to do a factory reset. I downloaded fluidnc-maslow4-0.84-win64.zip and ran full-install.bat. I received the following error.
C:\Users\shaun\Downloads\fluidnc-maslow4-0.84-win64\fluidnc-maslow4-0.84-win64>full-install.bat
  • ------ Erasing flash- *
    win64\esptool.exe --chip esp32s3 --baud 921600 erase_flash
    esptool.py v4.6
    Found 3 serial ports
    Serial port COM6
    Connecting…
    Chip is ESP32-S3 (revision v0.2)
    Features: WiFi, BLE
    Crystal is 40MHz
    MAC: 48:27:e2:c7:63:d8
    Uploading stub…
    Running stub…
    Stub running…
    Changing baud rate to 921600
A fatal error occurred: No serial data received.
  • ------- Installing filesystem *
    win64\esptool.exe --chip esp32s3 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x3d0000 wifi_s3\littlefs.bin
    esptool.py v4.6
    Serial port COM6
    Connecting…
    Features: WiFi, BLE
    Crystal is 40MHz
    Uploading stub…
    Running stub…
    Stub running…
Update: I ran the install-fs.bat and that seemed to do the trick.
