I think it’s actually better to lift from the column because the the lead screws and linear rods aren’t really designed to support the weight of the router in the lateral direction. The handles hold the weight of the router so the seld only has to support it’s own weight.
I hadn’t yet attached the top bracket to it, and setting it on it’s side,
pulled the screw heads through the bottom bracket (thus my suggestion that when
you have to re-do the injection molds, make those parts thicker)
