Larger and Faster Motors for G0 movement
Just ordered my Maslow with the idea in mind to give it more power and make it faster.
What is the latest on larger motors, larger sprockets, higher capacity motor drivers, and 24 vdc motor operation?
My speed needs are about rapid travel when not cutting. G0.
Thanks.
On my todo list is to play with running everything off of a 24 volt supply. You should be safe to just plug a 24 volt supply in and the motors should move faster…but I haven’t tested that so try at your own risk. The PID tuning values in the settings and the maximum feedrate will need to be adjusted in the settings.
