Would be nice to have ‘hardware’ limit switches on M4 starting to think of a limit switch as a mechanical element that attaches to the belt near the edge of the workpiece zone and using a spring.
If we coupled a spring to that mechanical belt stop the M4 can soft land and trigger the fault, avoiding damaging or stretching the belt when we hit the limit. Could sense that we hit the spring by the shape of the current profile ramp in the belts then issue the hardware limit event before overly straining the M4.
can you explain a bit more what you are thinking? the limits of the edge of the
workpiece are at different belt lengths as you move along the edge?
Oh dang clip on limit wont work maybe can use retroreflective tape under the perimeter of the spoilboard and IR emitter detector pair bounce off tape under toolhead.
how would that work if the sled is rotated an arbitrary amount
Also, does M4 have Z limit switches?
no it does not. you set the Z parallel by running it down against the motors
until it stops moving.
and if the beam is aimed directly below the bit, by the time it detects any
difference, you are already over the edge.
In addition, the best practice is to surround your workpiece with material the
same thickness so that there is something to support the sled at the edge.
