During my second cuts with the machine, I experienced an odd series of failures, but I’m not sure if they’re related.
At the time I was running v1.17.
While cutting, the machine disconnected from Wifi, but continued to cut, after a brief pause, although it never reconnected to my browser.
logs at this point:
Maslow-serial.log (4.5 KB)
Then a few minutes later, it paused again, and stopped cutting. At this point it reconnected to wifi, but had lost its positioning and told me I needed to retract the belts to zero.
Logs at this point:
Maslow-serial(1).log (2.3 KB)
Once I retracted and extended the belts again, when I went to jog the machine, I noticed a really strange behavior, the lower two belts were unspooling extensively, but the sled was not moving. At the time, I was trying to jog to the upper right direction. Initially I thought the issue was with the lower 2 motors being controlled improperly, but realize that the upper right motor was not pulling in any belt even though I was trying to move in that direction. This motor was completely unresponsive, and felt warmer to the touch than the other 3 motors.
See video of attempted jog in top right direction:
I tried updating the firmware to 1.18, and immediately after the motor did show signs of life for about a minute before it became unresponsive again. When it was moving, it had a higher pitched shriek than the others, and when retracting the belts, was significantly slower than the others.
Could this be a software or electronics issue? or more likely a failed motor? surprised since it has so little run time on it
I risk bought a new motor from the shop just in case because I’m a bit behind on this project
