I have purchase and used tons of shorter flat and round two flute XCAN endmills from for my smaller gantry mill. i recommend them becasue they are dirt cheap, last long time, and you can always have a fresh sharp bit around.
I’ve cut 3/8 aluminum on a 3018 mill with these $2 bits. of course test them on scrap before your $60 plywood.
they look fairly good, you would need to test them to see how well they plunge
straight in, I can’t tell.
given the maslow is pretty slow with a fast spindle, fewer flues is probably
better
compression bits only work if you are cutting deep enough to have both the upcut
and downcut portions in operation at the same time (which really means they are
good for full depth trimming after getting close to final size by other means)
If you are buying any bits from alibaba, do not use them with the standard 1/4" collet. You will need a 1/4" to 6mm collet. Otherwise the bit will likely come flying out of your router. Not fun… .lol I know technically 6mm is 1/4", but not in the world of CNC routing. 1/4" is 6.3mm. That .3mm makes a huge difference.
That is just an extension. Unless it is specifically designed for 6mm bits, which all bits from China are, you are taking a big risk that you or someone in the immediate vicinity will get injured. They make 1/4 to 6mm collets. I bought them. When I tried (when I fist bought them) using the 6mm bits from AliExpress, it came flying out like a bullet. Luckily I stepped away right before it happened. Just saying stay safe and use the right hardware before you end up injured.
I am familiar with Elaire I also buy from them.
But this is not just an extension it converts using 1/4" shank your router to ER11 system so you can install the appropriate ER11 collet 6mm, 5mm, 4mm, 3.5mm. etc. etc.
No, not without some modifications. You need to add some dimension to the diameter and find a way to mount the PCB. Mine is Kobalt 1-1/4 HP Trim Router 7 AMP #5207238
@dlang regarding the converter, you can always cut it down shorter. It still takes up Z range, about a half inch or so. To cut it you can place it in a drill press and spin then use a grinder with a cutting wheel to take care of business.
Looks like Dewalt 611 only came with 1/4" collet, curious where folks get 1/8" collets?
Was hoping to see affiliate link for recommended collet and 1/8" router bit on Shop — Maslow or the “not a shop” page. Am mostly using a 1/8" carbide single flute upcut bit. Thinking relatively low RPM deep large chip cuts with vac collectively help dissipate heat to prolong bit life. Configuring finish pass if/when needed.
Bar recommended this collet adapter. I’ve also got this, but I think the bits I ordered for it were metric or something, because it pulled out of the adapter almost right away while cutting.
That one had extra shipping charges to ship to Canada. This one looks the same but cost much less and delivers in 3 days. I will post how it works when I receive next week
