My actual problems with firmware 1.14
hi, I’m all in the green field in the simulator. I have a 4400x3600 frame, I don’t know exactly now.
I tried to raise the anchors so that there are no offsets.
The motor currents may have decreased a little by about a few tens of mA. However, the extreme positions go above 2000mA. But I managed to cut off the test section where I stopped.
I also noticed some instability of the balance on the sled.
I caught it on video.
I’m going to disassemble the machine and grind the coils. Check the overall mechanical condition.
I’m a bit surprised by this play. The lower parts of the plastic rollers are broken. I hope the belt can’t jump.
also the belt sagged when moving to the other side
Any ideas about tilting?
Why is the motor current actually increasing? I can’t imagine it, I think that if I moved the motor with 700mA across the entire surface to the anchor, I would pull the machine there.
