I need some help! I did the flash firmware dance with the button…
Took it out to the garage and got it to retract.
Then extended and anchored.
I never could get it to log onto my network or to see it on the network.
BTW, the network setup page -really- need some “english” applied to it. SUPER hard to tell what is what… Could we maybe describe things as the “Maslow server”???
Initial calibration seemed to work, then the second round pulled out the upper left belt and I hit stop. After that I couldn’t get anything to work.
I’ve re-flashed at least 5 times time and I think, maybe, its working? I’m getting this memory low error and the internet connection keeps dropping off (direct maslow server).
Too much sweating and swearing in the garage, gotta take a break…
Serial Messages
Index.html Version: 1.07
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Bottom Right pulled tight with offset -0.011]
[MSG:INFO: Top Left pulled tight with offset 0.000]
[MSG:INFO: Top Right pulled tight with offset 0.000]
[MSG:INFO: Bottom Left pulled tight with offset 0.000]
Stop
Release Tension
[MSG:INFO: Requesting state change from Belts Retracted to Releasing Tension]
[MSG:INFO: Cannot release tension from state Belts Retracted]
Retract All
[MSG:INFO: Requesting state change from Belts Retracted to Retracting Belts]
[MSG:INFO: Bottom Right pulled tight with offset 0.000]
Stop Maslow and Gcode
[MSG:INFO: Caution: Unlocked]
Retract All
[MSG:INFO: Bottom Right pulled tight with offset 0.011]
Stop
Retract All
[MSG:INFO: Bottom Left pulled tight with offset -0.011]
[MSG:WARN: Low memory: 13884 bytes]
[MSG:WARN: Low memory: 10724 bytes]
