My LED Trees for SOAK!
So a couple months ago I decided to lead a camp at SOAK the Oregon Regional Burn. I had a maslow for a while but I didn’t really have great time with 4.0. After I got my 4.1 kit I decided it was time to build a big project!
The idea is to create some trees with LEDs inside controlled by a microcontroller. The trees would be supported by a conduit shade structure in the middle.
There would be a box in the middle which would slot into a disk with some holes for the LEDs to go through.
Initial outside design
Once the box and disks were glued together I cut out the outside using a custom kerf bending design. The initial design looked a lot like wood but the pattern was very complex and it created a lot of small chunks of wood that clogged the vacuum.
This kills the maslow. I’ll talk about this later. It also took over 3 hours to cut one part. We were aiming to build 27 segments and we had a tight deadline of 2 weeks. So we simplified the design to be cut with a single engrave pass with a 1/4 in bit.
We then sanded everything and glued parchment paper diffuser on the inside. Then rolled the outside pattern around the disks and brad nailed it to the disk.
With a ton of help from my campmates we built 17 of these which was plenty for our stage because of a math error I did in the initial estimation. We were basically running the Maslow non-stop for about 2 weeks. We encountered a lot of issues and we must have taken the Maslow apart about 15 times during this period! I am also glad I bought a whole new 4.1 version so I could swap parts.
First Light!
Video of the finished stage
Some ideas/tips I had a long the way.
I wish there was a bit more extensive self test during startup. Most of the issues I had were the belts going slack after cutting for a while. It would be nice if it could move around and test the belt tension to verify the calibration is good.
I would love to have a start job on line function. Maybe this exists but I could not find it.
The button pusher from the not store is a life saver! Basically required for any tool change. I also should have gotten one of those remove before flight tags. I left that in a few times and made the router unhappy.
It’s very easy to over tighten the bolts in the circle part of the arm causing increased friction. I must have missed this in the build instructions but this caused us a lot of issues early on. Also greasing the large gear that holds the belt was pretty much required on all of the arms we had. I would love to see these added to a troubleshooting guide.
The best way I have found to take it apart is to lower the z on M4 until you can get a allen wrench into the ‘Support Riser Top’. Undo all the screws on the top and then send the z all the way up until it comes loose. It saved us a lot of time and it’s way easier to access these screws.
Dust is a killer. There was a couple time where our dust extractor failed. I am pretty sure this dust got into the z motors and then they stopped going up. Then the router pretty much bottomed out and carved a nice pattern in my concrete floor. hehehe. To combat this I noticed dust would be pushed out when the motors went up. So I increased the z clearance while traveling to 12mm hoping this would flush them out. I noticed a bit of an improvement but I am not sure how conclusive the results are.
I want to design a 3d printed part to cover / clean the screws before they push stuff into the stepper motors. I also noticed after they got dirty they would get very hot. So I also slapped some heat syncs on them.
I would also love to get a z encoder to stop the thing before it bottoms out. I am not totally sure how you would design one that could deal with all the dust though.
The persistent problem we had was the belts going slack after a few cuts. I think it would take about 9 hours of cutting or so. After that we would have to recalibrate to keep the belts taught.
One thing I have been thinking about is that my spoil board is 3/4 particle board. It was mostly flat but it does curl up a bit on one end. I didn’t think it would be a problem since it flattens out when the maslow moves to that area and pushes it to the floor.
Oh also none of my circles were round :smiley: it didn’t affect my project but I am going to have to do some measurements to figure out the right correction factor.
Well this is getting long… Bar if you read this I would love to get coffee with you can chat, I am Seattle based. I would love to contribute some of these ideas to a troubleshooting guide but I am not sure where to start.
Woah! This is a spectacular project! Nice work!
Can you explain this more, this sounds interesting!
This is interesting. Would doing Retract All → Extend All → Apply Tension work or do you actually need to run calibration?
I would absolutely love to get coffee. I’m downtown in Smith Tower if you ever want to drop by and check out the roof view, or if you don’t want to deal with downtown parking I can meet you pretty-much anywhere in the area
This is exactly how I tackled my 4.1 upgrade. @bar I bottomed the z axis in software. Then I was able to unbolt all the bolts holding the linear rails to the uprights. Then using software drive the z up and off the lead screws and rails.
@Bryan those are awesome project! Impressive run time to get them all done too!
Dano
Dano
Dano did a good job of explaining it but you lower the Z until the screws are accessible (1 in the pic below). Then remove the whole top part. Then move the maslow +Z until is is free from the Z motors. If found it a lot easier to work with these screws than the ones on the bottom of the sled.
I did try this and it was the same result. It would start out tight but it would be letting out too much slack and eventually become too loose.
I tried swapping the encoder boards and belts but it is still happening.
How about this Friday? Umbria is my favorite in Pioneer Square.
Friday is perfect for me, what time is good for you?
I have done that even with the flight tag, easy to forget!
The lamps look great!
@bar how about at 1?
Perfect
Not to sidetrack this thread, but I just wanted to say that it is cool to see you guys meeting up in person.
If I am ever in Seattle, I will be in touch!
