Not sure if I’ve seen this bug reported yet… I can connect to my Maslow, move it around, calibrate it, etc. However some actions produce no serial logs whatsoever. Non-log producing actions include:
- Running “Test” from the setup pane
- Running a file, even to completion
- Running a file and crashing due to an error
I do see logs when I initially connect to the Maslow:
Serial Messages
Index.html Version: 0.8
[MSG:INFO: FluidNC v0.79 (Maslow-Main-7b9f3a44-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:speed_of_light]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connecting...]
[MSG:INFO: Connected - IP is 192.168.0.118]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
Additionally, I see logs when calibrating (with fitness and such).
I just ran my first cut with the router on, and it failed after 20 minutes or so, I think it’s consistent with the ethernet/dust error, but I don’t have any logs to diagnose!
Thanks!
-Sam
