(1.07 private build) Maslow begin() startup code checks whether encoders and motors are connected which is neat.
If one or more motors or encoders are disconnected then Maslow goes into an error state flashing the red led. If that happens, Users need to fix hardware/wiring issues then power cycle Maslow so that beginning startup checks are tried again. Fair enough.
Example of motor code and call graph (note how Maslow_::begin is called within loop() after setup() has been called already) :
Unexpected behavior… Am not seeing the begin detected motor and/or encoder errors being logged in the browser. It’s as though log messages called by Maslow.begin logic are not being written to the serial port/stream, even though setup() logic has executed already.
The Maslow_::update() main loop detects and logs last error, but, that seems to be cleared before the actual error is logged. Am working around to at least see the last message…
if (error) {
static unsigned long ledTimer = millis();
static bool st = true; //This is used to blink the LED
if (millis() - ledTimer > 300) {
stopMotors();
st = !st;
digitalWrite(REDLED, st);
static unsigned long errorMessageTimer = millis();
if (millis() - errorMessageTimer > 5000) {
if (errorMessage != "") {
log_error("Error State: Latest Error: " << errorMessage.c_str());
//errorMessage = "";
return;
But, I don’t know why the begin setup related info/warn/error traces are not being emitted and relayed back to the web browser. Am mentioning because seems like it’d be helpful for Users to see those MotorUnit related error messages so they can quickly self help to go fix a broken/disconnected wire or encoder.
Repro steps…
- Power down Maslow
- Disconnect one of the motor cables (to simulate wiring/motor issue)
- Power on Maslow
- Maslow starts flashing red LED every 300ms.
Expected behavior…
- Related MSG:ERR entries visible in browser web UI.
Actual behavior…
- Not seeing log content for Maslow_::Begin code. Can see other log content generated by /src/Main.cpp::setup() and Maslow_::Update()
Serial Messages
Index.html Version: 1.07
[MSG:INFO: FluidNC v3.0.x (Maslow-Main-28dd52e1-dirty)]
[MSG:INFO: Local filesystem type is spiffs]
[MSG:WARN: Ignored key dc_servo]
[MSG:WARN: Ignored key cs_pin]
[MSG:WARN: microsteps value 0 constrained to range (1,256)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:...]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.0.46]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
