While running G-Code multiple “encoder read” errors come up,
so far the solution has been.
- Unplug the control board
- plug it back in
- calibrate (retract all /extend all)
- run updated G-code from last fail point
- pray
is this really an encoder problem or is it something else? ive swapped out the Ethernet cables but that didn’t seam to help, and the position of the encoder fault changes every time.
( of note, there was a dust collection system set up but that has been removed)
Serial Messages
Index.html Version: 0.84
[MSG:INFO: FluidNC v0.83 (Maslow-Main-39543985-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:******************]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.1.64]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Caution: Unlocked]
Jog: Z1
Jog: Z1
Jog: Z1
Jog: Z1
Jog: Z1
Jog: Z1
Jog: Z1
Jog: Z1
[MSG:INFO: Set to comply]
[MSG:WARN: Encoder read failure on Bottom Left]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 4 times in the last second]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 1 times in the last second]
[MSG:WARN: Encoder read failure on Top Right]
[MSG:WARN: Bad connection on Top Right encoder, failed to read 2 times in the last second]
[MSG:WARN: Bad connection on Top Right encoder, failed to read 27 times in the last second]
[MSG:INFO: Bottom Left pulled tight with offset -1554.596]
[MSG:INFO: Bottom Right pulled tight with offset -1607.460]
[MSG:INFO: Top Left pulled tight with offset -1611.025]
[MSG:INFO: Top Right pulled tight with offset -1664.061]
[MSG:WARN: Bad connection on Top Right encoder, failed to read 1 times in the last second]
[MSG:WARN: Encoder read failure on Bottom Right]
[MSG:WARN: Bad connection on Bottom Right encoder, failed to read 1 times in the last second]
[MSG:INFO: Center point deviation: TL: 0.372 TR: 0.220 BL: 0.801 BR: -0.372]
[MSG:INFO: Center point deviation within 15.000mm, your coordinate system is accurate]
Jog: Z-1
Jog: Z-1
Jog: Z-1
Jog: Z1
Home pos set for: Z
[G54:0.000,0.000,72.450]
[MSG:INFO: Tool No: 1]
[MSG:WARN: Bad connection on Top Right encoder, failed to read 3 times in the last second]
[MSG:INFO: Reset during file job at line: 148]
[MSG:ERR: Emergency stop. Update function not being called enough.1002ms since last call]
