Kyle_S
#1
So, after getting over a whole host of calibration issues, I managed to drop my sled while changing wood to test to see if I had it right this time.
The ring is badly bent, but all the other components seem fine.
Is there a place that sells only the ring? I don’t need all the rest of the supports or rollers, just the ring itself.
dlang
#2
you could switch to a linkage (either my top mount metal one or the wood ‘45
degree’ one)
from what I understand, getting a ring laser cut is fairly pricy.
bar
#3
I would contact the kit sellers to see if you can get a new one. We’ve also seen some pretty good results with folks just bending them flat again
