Should I lower cut speed to eliminate sloppy corners?
You might find some helpful advice from fellow members in my previous post about strange cut behaviour. Drag a many issue here i believe
I reduced the problem (not eliminated) by rounding the edge of sled, waxing bottom and reduced weight by 500g total. I also where possible as @aluminumwelder suggested move my sheet 200-300mm in from corners this totally eliminates problem. Hope this helps
