Solidworks 2018 and up, CAM Post Processor
Nice! I haven’t yet heard back from CAMWorks support, but that might just be what we’d need to get it going.
I downloaded the post files and the Unversal Post Generator. I set up a quick Maslow CNC machine in CAMWorks with the basic settings. I put together a quick program to test out what the generic GRBL post does from CAMWorks. This is the posted file:
CAMWorksTest.nc (1.3 KB)
My machine isn’t presently set up, so the only testing I could do would be to have it sit there and spin the motors xD
The one thing that stands out to me is that there is no safe startup block at the beginning of the program. There’s a G90 near the beginning, at least, but I didn’t see a G21 to tell the Maslow that we should be working in mm. It looks like it should run, although I would do so with caution, making sure my units are set right and everything. Or manually add the G20/G21 at the beginning to specify units.
Porbably have to play with the Post generator a little bit when I have time, or wait until CAMWorks support gets back to me.
While I do some significant advantages to CAMWorks/Solidworks CAM over Fusion 360 CAM, there are a couple of things I need to figure out before I can say that it’s distinctly better. What I can see being really useful from CAMWorks is the ability to save a ton of different machining strategies, and how much more control you get over your toolpaths. But I can’t figure out things like tabs without having to make a bunch of sketches and additional operations.
