Maslow Post Processor
Can someone tell me what post processor i can use with the Maslow.
I’m looking at cad/cam software I like to use and it lists a bunch a post processors to chose from to generate gcode.
thanks in advance
grbl or maslow
Thanks Orob, there’s no maslow but there are 2 grbls , grbl inch and grbl mm, since i work with inches I’LL choose that
stay safe and thanks again
They should both work since the machine will read gcode in either inches or mm. The inch vs mm relates to the gcode generated, not the original design so either one should be OK.
Thanks bar…good to know.
Hi. New to Maslow and just got my build and calibration done, so looking at next steps to get cutting. My understanding of this thread suggests that as long as the CAM software that I use (typically either Fusion or DeskProto is what I use) has a GRBL post-processor I would be OK to just use that. Is my understanding correct?
Reviving this thread because I wasn’t getting clarity going through the docs and the recent Kickstarter means there will be more folks like me who are jumping in without the benefit of experience on previous versions.
That is my understanding that basic grbl post for fusion should be fine. Fair warning I haven’t tried yet myself.
Dano
Kyle Burns rote:
yes, a grbl post processor should be good to use. Ideally a fluidnc post
processor, but I think fluidnc folks use grbl
There is a Maslow post-processor available for Fusion, and to my knowledge it is maintained to some degree. It’s been working for me…
I’m using Easel and generating grbl. I select the “cut outside of pattern” so I will get the actual size of the part like on my other CNC. However, my Maslow actually cuts on the line. When using a 1/4” bit this gives a part that is 1/8” along all edges too short. I don’t want to have to design parts larger by 1/8” so they’ll come out right. Any suggestions?
Your cnc doesn’t know where the line is, it just moves as instructed by the CAM
software. It may be that your maslow is cutting incorrectly (you would need to
do more testing, especially in different areas of your workspace)
Maslow Post-Pressor for LightBurn?
