Some pre-purchase questions
Hi everyone,
I’ve wanted one of these for some time, and think I may get one for myself this year for my birthday… :slight_smile: Particularly because I now see it can operate on the floor, so I wouldnt need to build an easel.
I’d be using it on my garage floor on the frame, since I can’t drill into the floor or walls.
Anyway, here are a few questions I couldn’t quite answer in looking around - probably there somewhere…
  1. how much waste is there? I see some connected to a shop-vac, but wouldn’t necessarily want that running for a long time. Any other ways it can be handled?
  2. What are the specs on cutting and tolerances? In other words, what are the smallest cuts and corners I can make, and the largest bit size, and speeds? Shallowest / Deepest? I’m not in a hurry, but don’t want to wait forever, and don’t want to break bits.
  3. I have a few different programs that might work for design - Illustrator and Rhino among them. Before buying the Maslow, is there a way for me to design and test/simulate whatever the results would be? I don’t know much about CNC software.
  4. Can I safely cut anything other than wood?
thanks!
it depends what size bit you use, a bigger bit will produce more waste)
  1. What are the specs on cutting and tolerances? In other words, what are the
we don’t have good info on this, other than the max speed the machine can move
is ~2000mm/min this is a fairly slow machine. most of the rest of it will
require experimentation
  1. I have a few different programs that might work for design - Illustrator
    about CNC software.
yes and no, there are gcode simulators that will show you how you have
instructed the machine to move, and CAD/CAM systems will show you the predicted
results. But the reality of cutting is that different materials cut differently,
and it’s a matter of trying to figure out the parameters. but the simulators are
fairly good at estimating how long it will take (they tend to be optimistic, but
it gets you a ballpark(
  1. Can I safely cut anything other than wood?
you can cut any material you could cut with a handheld router (really all that
the maslow is is a small trim router that is moved around by the belts rather
than your hands)
we’ve had people do plastics and aluminum that I know of.
Here are my piles of dust from a sheet of particle board cut into a bunch of polygons. I would not want to do this in an enclosed space without some form of dust control. Since you should never leave a CNC alone while running ( fire) I could see vacuuming or sweeping by hand every few minutes.
Quarter inch bit 1/2 in board 5 hours of cutting
In my limited testing The maslow was really precise but not necessarily accurate. I cut this sign for a friend in multiple passes and tried to cut and then chamfer the sides. after a tool change the chamfer was off by about a mm or two but the sign cut in one go with 6 passes on a V pointy blade looked great and very crisp. Look through the projects and what have you been cutting forum for ideas of what is possible.
