Spindle control via relay on Classic Maslow
@kyleschoen
Webcontrol for the Classic Maslow had it programmed in to use a relay via aux pins. I will link some posts below as I find them. I do not know how feasible these directions are when applied to modify the M4.
The relay is in the switch box controlling the AC to the bottom outlet which my spindle inverter is plugged into.
Relay I used was the 5 volt option from the link below. DISCLAIMER, they do quit working from time to time, in 2 years I went through 4 relays. I would suggest one with higher AMP rating.
The harness i used to connect my shield to the relay and for my auto z mod.
AMAZING! This is going to save me a ton of time, thank you so much!
BTW, did’t realize that was your spindle rig but you inspired me to create a snazzier electrical setup mounted to the frame that I posted earlier.
