one thing that people may not realize, the original kickstarter Maslow had a
completely manual Z axis, any time a Z move was needed, the machine would pause
and wait for you to change the router.
the existing hack of motorizing the depth knob of the router was something that
Bar came up with at the demand of the kickstarter backers and it works amazingly
well for a hack.
but as slow as the maslow moves, a 2.5HP router is drastic overkill, and so for
about the cost of a router (especially outside the US), you can ship a 500W
BLDC spindle, speed controller, and c-beam Z axis. It will be quieter, lighter,
faster, and probably have less runout.
Which brings up a feature the new board should have, support for a stepper for
the Z axis to make installing such a Z trivial. it’s far cheaper to buy a
pre-built Z axis with a stepper than to get one with a DC gear motor and
encoder, open loop matters less on the Z as it doesn’t move as much, and a nema
17 motor (mass produced for 3d printers) will be chaeper as well.
I agree that a slightly more expensive kit that is easier to setup should be
easily accepted.
As an example and by no means trying to say these are or should be the goals
of a maslow revision but It might be something like:
- Develop a scalable and adaptable large scale CNC (re-using as much of the
exisiting capabilities of the Maslow project and relevant opensource CNC
advancements as possible) capable of processing 4x8 sheet goods at 100%
coverage while still fitting in a typical one car garage/hobbyist space. The
accuracy and repeatability of the machine should be aaa and bbb across stock
materials of type and max thicknesss of ccc.
100% coverage may be negotiable, it’s good to have it as an option, but most
people work on sub-sheet sizes (just the hassle of getting a full sheet home
means many people get it cut where they buy it)
The maslow can come within a very short distance on the sides, but needs
improvement on the bottom
- Develop supporting workflow tools and integrations that lower the barriers
of entry for users new to CNC.
some of this is new tools, much of this is supporting existing tools (people are
really reluctant to tackle learning new CAD software once they know something)
- Target a price of no more than $750 for a self assembled kit with a total project cost for s typical user of $950 to first cut.
sounds reasonable
I think one of the perception issues with the existing Maslow is “it can t be
that good since its only $499 and a 'proper CNC starts at 5k, 10k whatever”.
Pricing is part of branding. By increasing the spec and smoothing off rough
edges and raising the street price target to $750 or $1000 I believe the
interested market and demand will expand not shrink. Especially if that
increase is accompanied by smoothing rough edges, like easier setup, improved
z axis, and most importantly improved and repeatable accuracy.
to be fair, part of it is that the maslow (especially the first design) was not
that accurate. We need to fix this (get the holey calibration merged and see how
much that helps everyone, it seems like a pretty clear win for everyone who’s
tried it)
