In the end I had to completely unscrew the PCB mount and remove around half of the cables to be able to get it to completely clear the router. Not a very difficult task, around 2 minutes or so.
Still have to do a full powered on test.
It hit me (when I woke up in the middle of the night) that the motors for the belts don’t have to be mounted to the arms, so many hours later, I have a draft CAD model (this shows a single arm so you can see the stuff in the middle)
It then has 3 lead screws driven with a belt from a single stepper for the Z axis. This allows for spindles >80mm diameter with an overall size smaller than the current version
I haven’t yet modeled all the plasic bits (the thing that rides on the lead screws and holds the spindle, the sled, the dust collection, and the vertical stuff from the sled to support the bearings and stepper at the top, extra material on the arms so you have a place to put screws)
I thought about putting the stepper on the bottom, but having it at the top leaves a nice hole for dust collection
since the motor will spin the entire arm when it pulls tight, you have to rely on the encoder telling you the belt isn’t moving rather than measuring current (and you have to watch out that you don’t damage your encoder connectors/wires by wrapping them around the sled)
I figure that the electronics, spindle power, and power brick can all be mounted to the sled between the main motors
the more I look at it and think about it, the more useful it seems to be to be able to run the spindle off the top rather than having to unclamp it, so I may just go with 3 steppers instead
Why not make the spools/arms the diameter of the sled and make the z axis independent of the spool/arm cluster. Your cad drawing may show that , but not quite sure
I do have the Z independent of the arms
spool size is a balance between larger spools hold more belt, but take more
material (more expensive) require larger systems to manufacture (more expensive)
As I currently have it sitting in CAD, it can hold a 85mm spindle but arms can be printed on a 213x230mm print bed
I did a bit more work, this may show things better
not counting the stepper sticking out the top, it’s just over 6 in tall (and I think I’m using much thicker bearings than the stock version, once I measure them I’ll adjust and it will shrink a bit)
I’ve got everything parameterized, so I can set different sizes pretty easily (things get a bit messy when the drawings overlap so it’s not quite seamless)
since I use stock motors and then have a 15mm tall coupler to the shaft to drive the arms, there is a lot of wasted space at the bottom, switching to motors that have long shafts on them would save a lot of space there.
If the motors are fixed then when the assembly applies tension to the belt, the torque reaction will cause the arm assembly to rotate out of true and the arm will not point at the anchor, but off to one side a little, putting a bend in the belt and changing it’s effective length.
In addition, as the Maslow moves about the work surface, and the arms move to align with the anchor points (if it is working as you intend) then as the angle of the arm changes, the belt will wrap and unwrap from the spool, again changing the belts effective length.
I think the only way to avoid this is to do as Bar has done with the design and have the gearmotors anchored to the arm assembly which is free to move. This closes the loop and eliminates the torque reaction.
I like your older suggestion of enlarging the ID of the arms and fitting the entire z-assembly inside, so the belt motors do not interfere with any supports.
While we are talking about belt driving gearmotors, it is important to note that one of the reasons we have so much trouble ensuring proper tension on the belt is that we use a gearmotor that is nearly self-locking. ‘Self-locking means’ that internal friction is high enough that you cannot backdrive the motor by pulling on the belt. This is convenient in that if you remove the power the Maslow does not fall down to the ground (if using vertical orientation) but it makes it hard to ensure proper tension on all belts, especially during calibration when you don’t know where the anchors are.
One solution would be the use of a direct drive motor with no geartrain, and a brake that engages automatically when power is cut. In this kind of setup, the motor current is exactly proportional to the belt tension because friction is minimal. On a vertical setup during calibration you just set the tension current on the lower two belts (set a constant current and ignore the encoders) and steer the Maslow with the upper two motors and encoders. This will perfectly prevent loose belts and the resulting problems, as well as allowing you to use the full calibration matrix right from the get go.
This kind of direct drive setup is used on industrial robots and works great. Unfortunately it is horribly expensive.
A compromise might be some kind of belt tension measurement device, perhaps using strain guages and flexion beams. This is done quite inexpensively inside virtually every digital kitchen and bathroom scale. Using this kind of device along with gearmotors like we already have, the lower two belts would be maintained at constant tension using a control loop in software, and the upper two gearmotors would drive the sled around while referring to their encoders.
Once calibrated, the Maslow would operate as it does now, but because you could monitor the actual belt tension, you could potentially implement a smoother movement control algorithm, and detect error conditions quickly. You might even be able to compensate for errors caused by the forces on the router bit as it cuts, or even the effects of frame flex of belt stretch.
good point, with nothing at all stopping the rotation, it will just rotate until
it tears off the encoder wires.
but if there is a stop, then it will rotate until it hits the stop.
the question is if the remaining torque will move the arm enough to matter
compared to the weight of the motor on the arm (shrug)
I wonder how much it would help if opposite belts spin in opposite directions
(as the belts are tight, torque will cancel out, as we move, one will pull
harder than the other is releasing). with the spool design I have, you could
just flip them over
True, but since the length of the belt is controlled by the encoder at the end
of the arm, not the motor position, it will automatically adjust for this (I did
think of this)
I had forgotten about the torque issue, but that was something we worried about
with the old maslow as well and didn’t end up being a problem in practice.
this shows one way that can be done in any case
Also as far as torque goes, I expect that the torque from the belt motors is
much less than the torque from the router, especially with a good size bit.
there is a potential problem, but it’s not the torque applied by the motor to the spool and sled
it’s that without the motor and spool both acting on the arm, the straight line will be to where the belt is tangent to the spool, not to the center of the bit. If the spools all go in the same direction, it will just unspool every belt.
since all the forces on the belts have to cancel out, I wonder if flipping belt directions on opposite sides would end up working?
(being able to move the drive to the other side of the spool from the feed is such an attractive thing. It lets the arm be thinner, and eliminates the possibility a loose belt getting tangled in the gears)
I wonder if it’s possible/reasonable to steer the arms? if you know the anchor locations and belt lengths you also know the angles needed, and you only need to rotate the arms through about 90 degrees (and one could be fixed with the entire sled rotating as it moves)
Curious of thoughts of having the spools be set radially, one in each quadrant.
Pair this with a wider opening in the center and the Maslow’s inherent versatility shoots through the roof.
to make the math work, you really want to have the belts pointed directly at the
center of the bit. If you don’t do that, then you become extremely sensitive to
the angle of the sled (so if you have a vacuum hose that limits the sled from
rotating, exactly how much force does it apply?, how much does friction on the
workpiece slow the sled rotation, things like that) The sled will rotate, if
only due to the torque of the router.
so you really want the belts to anchor to the sled in a way that allows the sled
to rotate underneith you without the bit moving.
If you put the spool out on the arm, then in the vertical mode you have more
weight on the arm that can distort them from hanging vertically. The spools on
the arm will also limit how close the arms can get to each other.
your sketch matches one of the early ideas of the ‘everything on the sled’
designs.
look at the linkage designs from the old maslow and you can see some other ways
of keeping the belt/chain pointed at the center of the bit
I’m realizing now that the vector through center isn’t maintained unless the belts are at 45 degree angles in my previous drawing. In light of that and a few other things you said, I would change the orientation of the linear rod supports so they don’t stick out so far and create routes for the spools to travel around the center within their quadrants, which would only impose limits where the spools would come into contact with each other. It may require a larger sled, or attaching things to an existing sled. May need to mirror the groove that the spool travels along above it as well to keep it from tilting when in tension.
replacing belts would also be much easier. Almost all of the servicing would be, tbh.
it’s also woth pointing out that there is nothing requiring the spool to be
parallel to the sled with the belt perpendicular to the workpiece. you could
rotate the spool 90 degrees so it looks like a snail
I would hazard that the ideal orientation would be the one that doesn’t propagate a twist in the belt and matches the orientation of the belt at the anchor.
with the original maslow, we found that if you find the center of gravity along
the Z axis and put the force there, with the belt/chain parallel to the
workpiece, you end up with very little tilting force on the sled.
now, that CG will vary depending on the length of the bit, how deep you are
cutting, etc. but getting it close works very well.
We control the anchor as well as the sled, the belt can go into the anchor in
any orentation
I realize that, and also that it would not be as easy to have the post for the anchor to be oriented differently. Trivial for some, but would require more complex woodworking for others. That has me leaning towards not changing that being better, even more so when I consider the motors rotating and potentially being more problematic than the spool with how far they stick out.
vertical post for the anchor, but then a slot that the belt goes through and
loops back on itself (with either a clip or wire ties to anchor it in place).
I am kicking myself a bit for not remembering ring-head screw bolts.
