Trouble saving file with ctrl S and auto save
Get error message when using Ctrl S to save and autosave also causes same error.
Saves with Dropdown menu save (I think).
Changed last Assembly to Fusion, and now saves with Ctrl S
Hi! Thanks for reporting it. I think for some reason you are losing authentication while the project is open and its failing to reauthenticate. I’ll work on fixing this!
When I came back to the project, after I thought, it had saved using the drop-down menu, it had not and I lost a number of changes. I had also copied the project while I was having difficulty saving, both had the same problem, i.e. missing changes. Changing the last Assembly to a Fusion fixed the save issue. I had also tried to reauthenticate, which did not help.
I finally found the issue with the save project feature and hopefully it won’t happen again. I think we are still experiencing some issues with our re authentication button so i’ve temporarily disabled it so it doesn’t mess up anyone’s project. Sorry for your lost changes :sleepy_face:
