Using Maslow without a proper workspace or garage?
Hi everyone,
I’ve recently learned about the Maslow CNC project and wanted to see if anyone else is navigating a similar space-constrained situation.
I am a complete newbie to CNC. I’ve dabbled with 3D printing, but I want to transition into making larger-format pieces- specifically furniture and architectural-scale components.
With a budget of around $500–$1000, Maslow seems like the only realistic option for me to get into large format fabrication. My problem is that I live in a tiny apartment in Tokyo. While I could technically clear enough floor space to lay down a sheet, the noise makes indoor cutting completely impossible (neighborhoods here are incredibly quiet, and apartment walls are thin).
I did consider desktop CNCs with acoustic enclosures, but a 400x400mm bed is simply too small for nesting furniture parts. I wish I had a garage to set up a permanent frame, but those are practically non-existent here.
Because the Maslow 4 sled itself can fit right into a backpack, I am wondering if a guerrilla-style cutting approach is viable. My plan would be to pack the sled, straps, and a small generator, head to an industrial or open area where making noise isn’t an issue (like a Tokyo riverbank), set up flat on the ground, and run the job.
I know the anchors still need to be perfectly rigid relative to the plywood sheet to maintain calibration. Has anyone successfully built a portable, flat-pack, or breakdown frame that can be quickly assembled on-site? Or has anyone tried running their Maslow entirely off a portable generator in the wild?
Would love to hear your thoughts on whether this is a brilliant mobile setup or an absolute logistical nightmare!
You might want to hold out for the smaller version that I have in the works which should be more portable.
yes, there are several frame designs that are portable, but portable in vehicle,
not a backpack (8-10’ long boards)
there was some speculation recently about making something that could be held
down with weights at the anchors (requing a find achors run each time you set it
up, which is getting less painful than it used to be)
I do like all of this. Having portable machines that you can set up anywhere is something I have done for years. I have a 15’ enclosed trailer that holds a portable workshop with many tools, and a generator to be able to run whatever I need. I also have batteries and an inverter hooked to a solar panel for backup, but it won’t run tools for very long.
I do have plans to set up another M2 in my trailer (smaller footprint of course, but I can calibrate that), and I think it will work just fine. Make sure you have a high quality power bar for surge suppression and spikes from the generator, and it should totally work.
For a portable frame for the M4, I think you could use high quality hinges to make an accordian type of frame, and use small jacks to level the workspace from the corners and center.
The bigger question is how do you plan to transport the workpiece?
I think what you are thinking of doing is totally viable, but will have limiting factors. A genset is great until it runs out of fuel before the job is done. Uneven ground may have an adverse effect on your cutting accuracy. There are some extra challenges there, but yeah, you could do it.
Frame ideas here. I did get it to work with stakes in the ground if I were doing that again I would make some 2by4 Tees to lift the belts up a bit Maslow_4/docs/FrameLibrary.md at Maslow-Main · MaslowCNC/Maslow_4 · GitHub
This is what m’y frame folds down to. Van? It’s very stable. Plus spoil board
Ok another solution here, I made these today and they worked really well. I think I could get all of this and a 4 foot by 3 foot spoil board and workpiece onto my bike trailer. That plus a generator is possible.
