Waste Board material
| kayaker37
June 4 |
I feel outdated, last time I went to buy a drill bit at Home Depot, most of the bits were no longer round, as well as the drills.
So I Googled and is this what you are referring to: Screw Head - Quadrex.svg
The Phillips/square screw drive, also known as the Quadrex , Pozisquare screw drive, is a combination of the Phillips and Robertson screw drives. While a standard Phillips or Robertson tool can be used, there is also a dedicated tool for it that increases the surface area between the tool and the fastener so it can handle more torque.[52]
Who carries this type screw, I don’t see any at Home Depot, although their deck screws have their own special head, as they come with a special bit.
I have a Hitachi 3.6v cordless driver, guess that won’t have enough power.
Visit Topic or reply to this email to respond.
In Reply To
| Dustcloud
June 4 |
To secure workpieces to my Maslow I use a Makita 18 volt rechargeable drill with heavy duty 1 5/8ā€ wood screws with a combined phillips/#2 square bit head. The #2 square driver is fantastic, never slipping, and provides really good control of the screw depth. With plywood, no pilot holes or counte…
To unsubscribe from these emails, click here.
Home Depot and I’m sure Lowes would have them too, sell a T-15, T-20 Torx head screw. You don’t need to push anywhere near as hard to keep the bit in the screw head.
On particle board for a wasteboard- The stuff is made from all the mill leftovers. Its got staples, screws, rocks, bullets…anything on the floor gets ground up and put in the mix. Not good for bit life. MDF is cleaner and you can get a light version (LDF) or a super light version (ULDF). We’ve tried all 3 at work for the vacuum table and like standard MDF.
