Currently using WebControl with Holey Calibration.
Does the calibration test pattern automaticaly adjust its size based on work surface dimensions. Meaning does a larger work surface result in a larger test pattern? Smaller surface, smaller patten?
Also, is there any way to change the depth of the cut the calibration routine uses? I only need holes that are 1/8 or 1/16 inches deep.
