We’re getting roughly 1.5 and are wondering what we should be.
Graham wrote:
We¢re getting roughly 1.5 and are wondering what we should be.
That is pretty good.
fitness is 1/estimated error in anchor locations so that is saying that it
thinks it has the anchors correct within ~.7mm
try cutting and see if it’s accurate enough for your project. That’s the real
question.
Cool! After some more work keeping the mounts rigid to rotation on the floor, we got up to ~2.2. I over tightened one and cracked it and it eventually failed and got pulled into the Maslow, but that will be fixed once reprinted. The general setup we found works is flex tape on the bottom of the mounts plus 50-70lb weight pinning the corner
