Every time I try uploading the GCODE (10.7MB) it throws a disconnected error code hadn’t had a problem on other versions adding even bigger GCODES (22MB) but will only recognize 2MB before error is thrown out and doesn’t finish the upload process is there a fix for this or is it possible to implement the code while having the MASLOW plugged into the computer, so I don’t keep losing connection.
What’s happening there is that while the file is uploading your browser thinks is not connected. The quickest solution is to turn off connection monitoring here:
Ultimately we need to come up with a better solution for uploading large files
THANK YOU SOOOO MUCH, that worked like a charm.
