Z-Axis Motor Wiring
Wow! That is a fantastic speed improvement.
Are you seeing any issues with the router not wanting to move up and down that quickly?
Not really, It seems to be moving very nicely. I do wax the router body as well at the plunge mount so that may help with keeping it moving easily. I’ll do a project post in a few minutes so you can see the cut I was working on.
I just finished my new sled with the alternative z axis. I am going to put that motor on there if it is working, it should work good with the ball screw setup.
That looks awesome! Yes, make sure you get the motor with the 270:1 gear ratio, and in the description it says that its the one that has 64 CPR. the other encoder definitely had something funny going on. The only other thing I did do which I’m not sure actually changed anything or not, I set up a macro to send the command $18=20.0 per a post by @blurfl. With that command plus the motor with 131:1 gears, I have seen a great speed increase. The wiring was very straight forward if you use the Maslow cable and splice in the new motor. 5 of the wires match color for color, the only odd match was going from blue on the motor to orange on the Maslow cable. Here is a picture.
Thanks for the information!
Sorry for posting so far after the original but I have been looking at potentially making my Z Axis move quicker, based on the post you have the motor from Ebay along with the gears from the Amazon motor? I am just looking to see what you have so that I can hopefully duplicate it.
Thank you!
It looks like they offer the correct motor with the 131:1 gears on amazon now. Here’s a link:
That is the same company that I bought mine from and in the desription it says that is does have 64 CPR.
Anyone have a link for the Connector parts needed to wire this up for the Stock Z-Axis wiring connector?
I thought based on what I saw above that it was just a matter of soldering the wires together and it looks that all but 1 are the same color. If you get the correct 64 CPR motor. I may be wrong though.
Yep, I just soldered them together and added some heat shrink.
Boo! Sounds Good tho, and thanks for finding this!
Can you upload a video of this mythical high speed Z in action?
If it was me I would look for a 6 pin connector and solder that in for easy motor removal. I am nervous that I am going to damage my mega shield connectors.
Ok, I got the motor above that @brazz04 recommended. I installed and tried it. No faster and the distance traveled was off. I researched and called @bar. (Thanks Bar again) I did the math on the gear ratio x the CPR of 64 and got the larger number for the Maslow settings in Advanced and Encoder setting.
WOW, it ran fast. I put a small ruler on my slide for the Z axis and played with the numbers also with the screw pitch and it travels now faster and accurately on the slide up and down. I will attach a video of it in action moving .5 inch. I recommend this upgrade and it was fairly straightforward. It bolts right up like the supplied motor.
What do you think of the 90:1 geared option of the same link as above? I have the same z rail I want to try and the torque is not THAT much less.
As far as I know, nobody has reported on any attempt to use one, so we don’t
know how well it would work.
I think it would probably work well, but someone needs to try it
I’ve looked into it, but I’m not ready to report. Most motors I’ve found other than the Maslow z motor have 16cpr encoders instead of the stock 7cpr encoder, which overwhelm the Mega when trying to reach higher speeds. The symptom is loss of z-axis accuracy at settings of (maxZRPM) $18 higher than around 20 (default is 12.6). I’m looking for a way to divide the quadrature down, but a bi-directional solution is proving hard to come up with. Links or experience would be welcomed :wink:.
What the hell, I’ll guinea pig for ya… ordered one of these:
Look forward to hearing the results!
Me too! :slight_smile:
Ignore that link i had it is the 131:1 motor posted above. …
I ordered and installed that motor. When I test the motors in GC things work super super fast as expected for the z. Now though while cutting I see no speed increase for the z and the depth of cuts is deeper than desired.
I did the 131x64 as the new z encoder number is there something else I should be changing?
Confused…
