I have a flat 2400mm x 4800mm table Im using for composite infusions for a truck camper that I’m building. I’m hoping for this table to double up as a Maslow v4 base.
I read that the belts are ~4400mm long so I did a quick sketch to see if I could process a 3600x1200mm board and it looks like it might be possible depending on how much of the belt is actually usable?
the possible issue would be in the top center of the workpiece (especially with
a vertical frame) where you are fighting gravity and the angle between the two
belts on the long side is the widest. Will there be enough power from the motors
to move the sled towards the edge (i.e. up)
@dlang is spot on. I think it should work, but we’re entering uncharted territory. That being said we’re here to help you figure it out if you run into issues so keep us posted
