Hello, Everyone
I was running into an issue where my vacuum hose would push up against the floor and ruin my cut for those projects cutting close the bottom of the work-area.
I tried finding an elbow, but none of them were either the right size or would put way to much stress on the clear router dust port.
I designed this 90 degree “mounted elbow.” basically fits the Rigid’s router port and 2.5in (45mm) “Dustopper” hose.
Attaches with #10x3 screw, which will go into the sled aprox 10mm
maslow_90_vaccum.stl (414.4 KB)
Here is the STL I hope it helps you too.
