Funny you should mention… I"m working on this. not quite production ready (one firmware change to make it work better) but see M4 ESP32 UI for stop vs abort - #10 by ronlawrence3 if you want to try an experimental UI that just uses a “play” button that turns to “pause” when you are running, then back to play if you pause or stop. Make sure you save your downloaded version or re-load it if this doesn’t work for you. Also any feedback is appreciated…
