I finally finished my frame, which folds up to the ceiling to save space.
Printed and installed my oversized corner anchors. Print files below.
Assembled my M4 without much issue.
Installed everything
and with some trial and error I managed to get a successful calibration.
One thing I didn’t completely understand during the calibration process is how to define the area the Maslow can cut. My frame is 2250 x 2250 (machine size?). My cut area, at this moment, is 1200 x 1700 (calibration area?). But when I use these values, the Maslow always goes outside the cutting area during the last calibration step.
So should I take the width or height of my cutting area minus the width of the sled to keep it inside the cutting area?
See a picture of the issue
Also, I noticed that the Maslow tilts a bit when it’s in the left top corner, at that moment it’s not fully supported by the frame, so that could be the reason.
I guess that that position is not even possible to do a cut, so maybe I shouldn’t care about that?
Or should I first fix this issue and make sure the Maslow stays inside my cutting area during calibration?
Anyway, I’m really happy I’m almost ready to start my first cut. But at this step, I’m a bit lost. When I followed the setup docs, it seems to stop at calibrating and controlling the Maslow with the web app, with very basic ‘how to run gcode’ info.
I found a lot of helpful info in the forums, but I want to double-check some things as I’m not sure what to do next. It would be great if there was an extra chapter in the setup docs with a dummy step-by-step guide to making your first cut.
If I understand it correctly, when I want to cut something, I first have to move the Z up and install the router bit?
To install the bit I have to remove the Maslow from the frame first?
Then when it’s installed, I have to lower the router until the bit touches the wood, and that would be my Z home position? Then, when I have uploaded my gcode file, how do I define the depth of the cut, and at what depth should I do multiple passes?
It’s a bit scary to just try and see what happens, I don’t want to damage anything now I got that far ![]()
So it would be great if someone could help me.
Some images of my setup:
Calibration finished
Folded up
My printed anchors. If anyone is interested, I uploaded the print files below
They have a top part where I attach the belt ends into and a bottom spacer which fits into the corner of the frame and helps to keep the bolt in place.
Maslow corner anchor.3mf (106.7 KB)
Maslow corner anchor spacer.3mf (23.6 KB)
