Last time I loaded ground control 1.26 on hundreds of Mega2560 boards one by one and it was super boring took me about 2 or 3 days on and off.
I’m guessing that is the only way, but thought the community might know a more efficient method?.
edited to add:
I found this post below, but do not understand what the heck he is saying? Sounds like he made a custom wiring harness that plugged into many boards at once and then connected one via usb to the pc and it programmed the entire batch at once??
SOLVED… Frist thank you all for you input I found it to be extremely invaluable. It was a simple fix but I found out how to upload a sketch to many Arduino’s at the same time. This was key!!! - You connect all the GRN in parallel (from the FTDI - the DTR connection and the Arduino’s GRN) , the TX from the master serial (in this case my FTDI) connects to all the RX on the slave Arduino’s in parallel and the GRD on all connected together as well in parallel. The only down side is that you can’t receive a verify from the uploaded. But it’s not needed in this case. Again thank you for the help.
So after some research it sounds like I take this FTDI and run the wires parallel to a bunch of Arduino boards using little header wires (probably best to get a shield made to make it more idiot proof and faster )
wonder how many boards can be programmed in parallel?
Wonder if the time making a motor shields for half a dozen boards will be gained back in faster programming.
Does this sound like I am understanding this correctly or am I totally off track?
Setup your sketch so that it can be uploaded using the arduino cli
This involves creating a makefile that references the arduino cli libraries then you can upload by running make upload . Unfortunately this isn’t well documented.
Create a udev rule that recognizes when an arduino is plugged in
awesome solution if I knew baic linux programming, but honestly would probabaly take me more than 2 days to figgure out, which is about how long it takes to just manually do them one by one.
you could pull the command to flash the arduino from webcontrol, so that fixes the first one.
the udev rule could be a file named:
81-arduinoflash.rules
that would need to be made and placed in the /etc/udev/rules.d folder
inside it could have:
ACTION=="add", ATTRS{product}=="Arduino SA Mega 2560", SYMLINK+="ArduinoPgm";
RUN+="/usr/local/webcontrolprogramscript.sh 'ArduinoPgm';
where the webcontrolprogramscriipt.sh is located in /usr/local/bin and has appropriate permissions. It would then take the ‘ArduinoPgm’ sym link as the device to program as an input arguement and execute.
I don’t know how to make it beep. I can find the webcontrol command later today and try it on my linux system later, but maybe this will get you started.
