I’m in the process of building my first maslow and having a lot of fun! I got to the part where I am supposed to attach the arduino to the frame and had a couple of questions:
Where exactly should it be attached? The instructions say to attach them to the back of the plywood, but doesn’t the plywood occasionally get cut into? Does anyone see a problem with attaching it here:
I’m supposed to use 4 screws to screw the board to the wood. The head of the screws included are too large to fit in two of the holes. Is my setup below going to work ok?
Over heating can sometimes be an issue depending on your settings and where you’re cutting. A fan of some kind helps. Don’t cover it up to block air flow.
