Hello here is an update of my experiment to go outside the lines…
My setup was like this:
It is a big table in the middle of my shed and the anchors are on the walls.
Since my table is longer on the picture left side I was gonna test outside the calibrated area there, but I would not be able to go to the corner very far…
So I decided to extend the table for this experiment and shifted my waste boards towards one corner. From previous test I already found out that while maybe not completely accurate mm wise, the Maslow does seem to be very symetrical in its deviations from the expected. So I thought this time I’de only test on corner see how the Maslow behaves outside the lines(see here for the previous measurements: Having trouble after calibration - #56 by Gijs )
So here are the results, Is is all done in the top left corner from the Maslows point of view.
The diagonal cross or X is the center of the normal calibration area. I calibrated at 1600x1000 so this one quadrant (top left) is 800 by 500 in the pictures from the X (0,0) to the white tape (about -800,500)
Within the calibrated area the lines seem to go as planned. Although it does start to get a bit wobbly on the side close to the white (but still in the green).
Outside the lines it starts to get really wobbly but the overall dimensions still seem to stay pretty good.
The wobbly is directional. What I mean is if for example i move from -900,0 to -900,500 the sled wobbles side to side and also wants to lift up on the bottom side.
Doing the same move at x=-1150 the sled actually lifts up several inches and slams down again. This might have to do with the board i am using which is pretty rough, but mostly it is from the weird forces so close to the corner.
Going the same path back down (from y=500 to y= 0 at any X value outside the green) the sled has no problem and makes a straight line. You can see in the pictures some lines are wobbly and straight, the wobble was from going up, the straight line from going down on the same line. Here also the dimensions and straightness are not bad when the wobblies are not included…
Anyway, I hope it helps
Oh yeah, the red tape is where the red area starts the long white tape is where the white area starts, inside the white tape is the green area but I do not have green tape.
Overview (picture taken from right middle from the Maslows perspective):
Calibrated area 1/4 top left:
Beyond the calibrated area:
Detail wobblies:
A video of the worst wobblies:
