I will check tomorrow at once I’m at work and I will be posting several serial logs so you guys can give it a look and let me know if I’m missing something. i thought giving it a rest and coming back fresh might help but still nothing. thank you and David for helping out.
Maslow-serial.log (2.7 KB)
Maslow-serial (1).log (2.3 KB)
here are some logs you guys can check them out.
The thing that pops out to me most is these two:
[MSG:INFO: Top Right pulled tight with offset 0.258]
[MSG:INFO: Top Left pulled tight with offset 0.075]
[MSG:INFO: Bottom Right pulled tight with offset 6.485]
[MSG:INFO: Bottom Left pulled tight with offset 0.172]
[MSG:INFO: Top Right pulled tight with offset 0.193]
[MSG:INFO: Top Left pulled tight with offset -0.021]
[MSG:INFO: Bottom Right pulled tight with offset -6.646]
[MSG:INFO: Bottom Left pulled tight with offset -0.032]
In both of those the bottom right belt is off, which would fit with a magnet slipping. The part that I can’t figure out is why it would be off by exactly the opposite amount the second time. That feels like something else to me.
If you do it a couple more times do you see anything funky with that bottom right one or was that a one time thing?
Maslow-serial (2).log (3.0 KB)
here is another one and the only thing that I can see and feel is shaking when the belt is being extracted.
Those look totally normal to me
