I can’t seem to get my maslow4 to calibrate. I thought maybe an issue was with the motor idler being to tight so I tore it apart and adjusted all the motors back to losen the fitness. I’ve tried extending and retracting multiple times to see if it zeros I get the following:
[MSG:INFO: Top Left pulled tight with offset 0.011]
[MSG:INFO: Top Right pulled tight with offset 0.032]
[MSG:INFO: Bottom Right pulled tight with offset 0.011]
[MSG:INFO: Bottom Left pulled tight with offset 0.000]
Below is the full log of the session but I’ve reattemped 20ish times now all with basically the same results. I checked my frame and it’s about .5" out of square im going to try and adjust that but it seems pretty voilent when doing the calibration. I’m not sure if I’m missing something or if I just have an issue with my build.
Serial Messages
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Zeroing z-axis position]
[G54:0.000,0.000,-4.000]
[G54:0.000,0.000,-10.000]
[MSG:INFO: Top Right pulled tight with offset -1726.598]
[MSG:INFO: Top Left pulled tight with offset -1720.447]
[MSG:INFO: Bottom Right pulled tight with offset -1856.580]
[MSG:INFO: Bottom Left pulled tight with offset -1831.877]
[MSG:INFO: Center point deviation: TL: 0.230 TR: 0.351 BL: 18.237 BR: 2.882]
CLBM:[{bl:1919.35, br:1905.29, tr:1901.98, tl:1903.66},{bl:1824.68, br:1930.23, tr:2003.14, tl:1870.84},{bl:1657.58, br:2027.87, tr:2146.23, tl:1807.42},{bl:1731.58, br:2101.85, tr:2101.49, tl:1717.70},{bl:1821.56, br:2176.43, tr:2032.57, tl:1632.71},{bl:1998.73, br:1983.75, tr:1825.59, tl:1842.79},{bl:2192.62, br:1805.97, tr:1630.63, tl:2045.97},{bl:2100.67, br:1850.30, tr:1795.01, tl:1947.60},{bl:2031.78, br:1631.49, tr:1835.15, tl:2172.08},]
Computing... This may take several minutesFitness: 0.1159719 in 100
Fitness: 0.1159719 in 200
Fitness: 0.1159719 in 300
Fitness: 0.1159719 in 400
Fitness: 0.1159719 in 500
Fitness: 0.1159719 in 600
Fitness: 0.1159719 in 700
Fitness: 0.1159719 in 800
Fitness: 0.1159719 in 900
Fitness: 0.1159719 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
