Calibration doesn’t work
I’m not sure what I’m doing wrong. But Iv build a frame. Gone through the calibration process a couple times and nothing is working.
Says it’s ready to cut but can’t even get it to jog. Clicked home and it just unwound the belts.
Iv tried attaching a video of what it’s doing but won’t let me do anything over 8mb.
Just keeps restarting the fitness saying it’s to low.
Sam
Can you try following along with this video and see where what you are seeing is different than what is in the video?
Iv tried following that about 10 times so far.
So frustrating. I’m uk based so this is taking forever to get sorted with the time difference. It’s better today but when I try and calibrate the bottom belts don’t go tense. They stay slack.
I still get the restarting fitness constant scrolling message in the code.
Just says calculated fitness to low. It’s a Maslow 4 and just upgraded the firmware. This is the first time using it since it arriving last August. Something isn’t right. !!!
Can you please help? I can’t see anything I’m doing wrong.
Iv got it set up vertically and the sled keeps falling off the bottom. This thing is seriously not right.
It does the frame flex. But only seems to do it once not twice then all the belts extend and crunch together. !!!
The bottom 2 belts are almost fully extending during calibration. It’s almost perfectly centre when I hang it on the frame. Then it runs calibration and completely goes off the ply.
All I keep doing is exactly what your video says but it’s not working!!!
This sounds to me like the machine thinks that it’s in horizontal mode. It’s not expecting gravity to be pulling down on it like that which is why it goes off the bottom.
Can you double check the setting for horizontal vs vertical mode is correct?
Also check the Maslow orientation, the power to the maslow board must be coming out in a down direction. I had a similar problem when I mounted mine vertically and had the power pointing up. I also have a 240V router..
I think this is it!! My wires are pointing upwards!
Il try it in the morning. Fingers crossed!
I did make sure a couple times it was vertical. I think Ian’s right with the board being upside down. Thinks the bed is upside down.
so this looks to have sorted it not falling off the board. but i am still getting fitness to low scrolling messsage keeps restarting. any advice? @bar ?
Serial Messages
Index.html Version: 1.05
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:TP-Link_HomeOffice]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.1.107]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Caution: Unlocked]
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Top Left pulled tight with offset -0.021]
[MSG:INFO: Top Right pulled tight with offset -0.021]
[MSG:INFO: Bottom Right pulled tight with offset -0.118]
[MSG:INFO: Bottom Left pulled tight with offset -0.054]
Extend All
[MSG:INFO: All belts extended to 1750.000mm]
Calibrate
[MSG:INFO: Requesting state change from Belts Extended to Calibrating]
[MSG:INFO: Machine Position found as X: -10.167 Y: 39.892]
[MSG:INFO: Center point off by: TL: 0.000 TR: 0.000 BL: -44.523 BR: -73.298]
[MSG:INFO: Machine Position computed as X: -8.377 Y: 54.531]
[MSG:INFO: Measuring Frame Flex]
[MSG:INFO: Flex measurement: TLBR: 3.025 TRBL: 4.126]
CLBM:[{bl:1904.15, br:1896.53, tr:1902.82, tl:1900.74},{bl:2006.70, br:1793.34, tr:1800.80, tl:2008.10},{bl:2109.22, br:1896.24, tr:1694.44, tl:1920.46},{bl:2012.59, br:1997.04, tr:1798.89, tl:1804.34},{bl:1910.60, br:2100.80, tr:1915.73, tl:1692.55},{bl:1796.32, br:2004.95, tr:2010.93, tl:1791.93},]
Computing… This may take several minutes
[MSG:INFO: Requesting state change from Calibrating to Ready To Cut]
[MSG:INFO: Succeeded]Fitness: 0.0792421 in 100
Fitness: 0.1010021 in 200
Fitness: 0.1435367 in 300
Fitness: 0.2483256 in 400
Fitness: 0.3259596 in 500
Fitness: 0.3385406 in 600
Fitness: 0.3469373 in 700
Fitness: 0.3532391 in 800
Fitness: 0.3587685 in 900
Fitness: 0.3645375 in 1000
Fitness: 0.3709971 in 1100
Fitness: 0.3762129 in 1200
Fitness: 0.3816153 in 1300
Fitness: 0.3889783 in 1400
Fitness: 0.4011427 in 1500
Fitness: 0.4182128 in 1600
Fitness: 0.4435975 in 1700
Fitness: 0.4539245 in 1800
Fitness: 0.4552828 in 1900
Fitness: 0.4555065 in 2000
Fitness: 0.4557196 in 2100
Fitness: 0.4559958 in 2200
Fitness: 0.4564096 in 2300
Fitness: 0.4568854 in 2400
Fitness: 0.4576006 in 2500
Fitness: 0.4584618 in 2600
Fitness: 0.4595885 in 2700
Fitness: 0.4611016 in 2800
Fitness: 0.4631067 in 2900
Fitness: 0.4654751 in 3000
Fitness: 0.4687643 in 3100
Fitness: 0.4698101 in 3200
Fitness: 0.4698101 in 3300
Fitness: 0.4698101 in 3400
Fitness: 0.4698101 in 3500
Fitness: 0.4698101 in 3600
Fitness: 0.4698101 in 3700
Fitness: 0.4698101 in 3800
Fitness: 0.4698101 in 3900
Fitness: 0.4698101 in 4000
Fitness: 0.4698101 in 4100
Calculated Fitness Too Low. The process will automatically try again.!
Calibration values:
Fitness: 0.4698100750488708
Maslow_tlX: 22.1
Maslow_tlY: 2029.6
Maslow_trX: 3215.5
Maslow_trY: 2031.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3227.7
Maslow_brY: 0.0
RestartingFitness: 0.4344721 in 100
Fitness: 0.4528211 in 200
Fitness: 0.4551070 in 300
Fitness: 0.4554559 in 400
Fitness: 0.4556806 in 500
Fitness: 0.4559280 in 600
Fitness: 0.4563006 in 700
Fitness: 0.4567429 in 800
Fitness: 0.4574212 in 900
Fitness: 0.4581841 in 1000
Fitness: 0.4592601 in 1100
Fitness: 0.4606620 in 1200
Fitness: 0.4624705 in 1300
Fitness: 0.4648654 in 1400
Fitness: 0.4676270 in 1500
Fitness: 0.4697909 in 1600
Fitness: 0.4697962 in 1700
Fitness: 0.4697962 in 1800
Fitness: 0.4697962 in 1900
Fitness: 0.4697962 in 2000
Fitness: 0.4697962 in 2100
Fitness: 0.4697962 in 2200
Fitness: 0.4697962 in 2300
Fitness: 0.4697962 in 2400
Fitness: 0.4697962 in 2500
Fitness: 0.4697962 in 2600
Calibration values:
Fitness: 0.46979619207636103
Maslow_tlX: 22.4
Maslow_tlY: 2029.7
Maslow_trX: 3215.8
Maslow_trY: 2031.5
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3227.9
Maslow_brY: 0.0
RestartingFitness: 0.4333104 in 100
Fitness: 0.4333104 in 200
Fitness: 0.4333104 in 300
Fitness: 0.4333104 in 400
Fitness: 0.4333104 in 500
Fitness: 0.4333104 in 600
Fitness: 0.4333104 in 700
Fitness: 0.4333104 in 800
Fitness: 0.4333104 in 900
Fitness: 0.4333104 in 1000
Calibration values:
Fitness: 0.43331042709978873
Maslow_tlX: 50.4
Maslow_tlY: 2035.7
Maslow_trX: 3238.9
Maslow_trY: 1993.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3253.7
Maslow_brY: 0.0
RestartingFitness: 0.4461467 in 100
Fitness: 0.4461467 in 200
Fitness: 0.4461467 in 300
Fitness: 0.4461467 in 400
Fitness: 0.4461467 in 500
Fitness: 0.4461467 in 600
Fitness: 0.4461467 in 700
Fitness: 0.4461467 in 800
Fitness: 0.4461467 in 900
Fitness: 0.4461467 in 1000
what should the fitness be?
@bar @ian_ab so it looks like the calibration is better now. i did a full rest and new index and maslow.yaml file
its running through the fitness which is now around 0.6 but its at fitness figure in 70000 how many times does it do it? it hasnt restarted but seems to be going on for a long time?
ITS ALIVE!!! finally after lots of troubleshooting its working. !! main problem was the board and the maslow and index files i think. thank you everyone for the help!
Great, have fun with it now. Glad to be able to help
