I’ve run thru the process multiple times with no luck. Any suggestions would be appreciated.
Thanks in advance.
Serial Messages
[MSG:INFO: FluidNC v0.73]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:WARN: Ignored key maslow_calibraiton_grid_height_mm_Y]
[MSG:WARN: Ignored key Maslow_Acceptable_Calibration_Threshold]
[MSG:WARN: Ignored key cs_pin]
[MSG:WARN: microsteps value 0 constrained to range (1,256)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Config messages ran]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Napili]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 10.0.0.63]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
error:3
error:3
error:3
$Config/Filename=maslow.yaml
$AP/Country=01
Maslow does not know belt lengths. Please retract and extend before continuing.
error:9
error:9
[MSG:INFO: Top Right pulled tight with offset 0.000]
[MSG:INFO: Top Left pulled tight with offset 0.000]
error:3
[MSG:INFO: Bottom Right pulled tight with offset -1.514]
[MSG:INFO: Bottom Left pulled tight with offset -5.411]
[G54:0.000,0.000,0.000]
[MSG:INFO: Zeroing z-axis position]
[MSG:ERR: Cannot run calibration until all axis are extended fully]
error:3
error:3
error:3
[MSG:INFO: Set to comply]
error:3
error:3
[MSG:INFO: Bottom Right pulled tight with offset -1385.073]
[MSG:INFO: Top Right pulled tight with offset -1561.853]
[MSG:INFO: Bottom Left pulled tight with offset -1779.334]
[MSG:INFO: Top Left pulled tight with offset -1945.786]
error:3
error:3
[MSG:INFO: Center point deviation: TL: 0.411 TR: 0.329 BL: 26.885 BR: 1.024]
[MSG:ERR: Measurement error, measurements are not within 2.5 mm of each other, trying again]
[MSG:INFO: Max deviation: 5.883]
[MSG:INFO: Bottom Right 1794.786]
[MSG:INFO: Bottom Right 1794.679]
[MSG:INFO: Bottom Right 1794.647]
[MSG:INFO: Bottom Right 1794.657]
[MSG:INFO: Top Right 1722.876]
[MSG:INFO: Top Right 1722.887]
[MSG:INFO: Top Left 1885.313]
[MSG:INFO: Bottom Left 1896.596]
[MSG:INFO: Bottom Left 1890.713]
[MSG:INFO: Bottom Left 1889.801]
CLBM:[{bl:1817.29, br:1816.87, tr:1791.90, tl:1815.15},{bl:1721.29, br:1747.74, tr:1901.68, tl:1900.71},{bl:1514.78, br:1974.02, tr:2100.91, tl:1698.70},{bl:1621.00, br:2028.69, tr:2001.17, tl:1616.23},{bl:1705.92, br:2095.11, tr:1939.45, tl:1539.43},{bl:1885.32, br:1889.73, tr:1722.86, tl:1794.65},{bl:2094.90, br:1699.42, tr:1516.31, tl:1978.50},{bl:1999.74, br:1616.95, tr:1668.96, tl:2020.97},{bl:1938.13, br:1539.97, tr:1716.94, tl:2099.70},]
Computing… This may take several minutesFitness: 0.1437404 in 100
Fitness: 0.1437404 in 200
Fitness: 0.1437404 in 300
Fitness: 0.1437404 in 400
Fitness: 0.1437404 in 500
Fitness: 0.1437404 in 600
Fitness: 0.1437404 in 700
Fitness: 0.1437404 in 800
Fitness: 0.1437404 in 900
Fitness: 0.1437404 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
