talk to your metal supplier about the top pantograph kit
With my metal supplier, the cost of materials is a small part of the total cost (aluminum instead of stainless would save ~$2/set) I’d lay odds that it’s in a similar price range to the existing chain brackets, since the existing brackets have so many holes cut in them, and are then bent and painted. If you want to eliminate the 2x3 spacer, you could make a metal bracket instead pretty trivially.
Do you still have the laser cutters you purchased for the Makesmith project? could you use them to cut out the 45 kit that @pillageTHENburn designed?
I think we are convinced that either kit is FAR better than the stock kinematics, and so I would hate to send out more of the existing kits rather than switching to something we know will work far better.
I know you are interested in the ring approach, but that is going to require a bigger box, while either of the linkage kits will fit in the existing boxes. As @pillageTHENburn documented in the ‘throwing my hat in the ring’ thread, there are good reasons to think that either linkage approach is going to work better than the ring approach, and they are far cheaper (no bearings to purchase, linkages are far more efficient space wise)
I’m not convinced that either the top-mounted or the 45-degree linkage is the best option for automatic inclusion.
The top-mounted pantograph is rather difficult to disconnect the chains from, making chain calibration more of a task than it should be. It overhangs the sled and interferes with access to the collet area.
Variations in sizes of routers mean that the best size for the 45-degree linkage is still being determined. Users in Australia and New Zealand may need a linkage they fits around a modified plunge base.
Neither of the linkage kits come with the necessary risers, very important for accurately positioning the linkage. Instructions for determining accurate placement during installation will be needed.
The ring linkage may share some of these issues, may solve some of them, and will no doubt introduce new ones. I don’t think we’re ready to choose a ‘standard’ yet, though.
We need to change the calibration so that you mark the chains in the home
location, so that you only go through the chain calibration once, and then you
can leave the chains attached to the sled forever.
I would remove the router for changing bits
It’s also easy to expand to a wider size (either initially, or for someone to do
so at home if they need especially long arms, the exact length of the arms don’t
matter, just that they match, cut 4 pieces of 3/4" wide material and clamp them
together and drill a hole in each end of the stack with a drill press)
I think there are going to be sizes of routers that you will have a very hard
time making any 45 kit reach around. If you are trying to clear a 12" wide
router, the mounts for the 45 kit need to be at least 6" away from the bit
horizontally, (about 17" between the mounting points, amost double the size of
the current links)
accurate placement isn’t that hard with either kit, put the hole that the chain
attaches to at the bit and mark the other two holes and you have the correct
mounting position.
The thickness of the router isn’t that critical. It needs to roughly balance the
sled, but since the router (a significant amount of the weight) moves in and out
during operation, there is no one ‘right’ height for the riser. It just needs to
be ‘close enough’ so that the sled doesn’t tilt (and especially doesn’t tilt
away from the workpiece, so ‘too tall’ is better than ‘too short’) and a 2x4
(@3.5") is in that ‘close enough and a little tall to be on the safe side’
range.
The thing is, any of these options are going to be a huge andvantage over the
stock design. On a scale from 1-100, all of these are above 90, while the stock
setup is probably down around 30.
I’d rather we ship the next 50 or 100 kits with the ‘wrong’ kit that supports
triangular kinematics than to ship them with the stock kinematics. When the
second batch went out we hadn’t yet tried linkage kits, they were a brand new
idea. but by now we know how much simpler and more accurate they are.
That trivializes the process of mounting the linkage accurately 3" above those holes in the sled. The holes through the riser must be accurately perpendicular to the sled surface, with no lateral slop. Remember the short list of simple tools for assembling the frame?
The router base needs to be removed to verify that the center of action of the linkage is accurately placed on the axis that the bit will occupy, because the router base interferes with that measurement.
This means that a fixture is needed to provide that axis, and also to verify that the base is re-mounted accurately as well.
If we’re looking for accuracy, we need to be able to measure and adjust to achieve it. A fixture to verify placement and a mounting arrangement that permits adjustment could help a lot. I’ve worked on these issues on both kits, and I don’t think either one is refined enough yet.
No, leave the router in place, put a bit in the router that you can position
with (either a 1/4" bit for the 45 kit, or a pointed bit for the top mount kit)
position the chain hole on the bit on the bottom of the sled. clamp/tape the arm
to the sled in this position
drill through the other two holes on the arm.
position the riser block on the other side of these holes, mark the outline of
the riser block(s) and drill pilot holes
flip the risers and align with the outline you drew above and repeat
now bolt everything together.
yes people can drill crooked holes, but they can also mount things to the stock
sled in the wrong place. The more careful the person is, the more accurate the
result.
In any case, the results should be good enough to accurately cut out a more
accurate set of riser blocks if that’s desired.
we don’t need a fixture for either kit to drill the riser blocks
But if Bar is willing to spend a little more money, a metal mount for the top
mount kit that has the holes in it at the right distance will only cost a few
dollars, or for a couple bucks more it can have a bent piece that allows it to
be mounted directly to the sled.
I’m not sure I have much to add that @dlang hasn’t already brought up.
I totally agree, the router does not need to be removed to get accurate measurements for sled drilling. In the instructions on the wiki I say to extend the bit through the sled and mark and drill from the back.
A drill press makes this pretty simple but it can be done with a hand drill and I bet you I could even get good results with a brace and bit (now I might have to try it to prove it!). As David said, the more careful the person is the more accurate their results will be; that goes for all parts of assembling a Maslow (or linkage etc.).
There are a lot of kits out in the wild now, and many of them are in use. The feedback I’ve received so far has been quite positive, hopefully more and more will get built and we can get some good data soon.
-Logan
With respect, I don’t think you’ve actually done this. Flipping the riser only works if the riser is exactly centered on both holes on both sides, and at the exact same distance from the center. Making a .5mm error here is exaggerated at the center, further affecting accuracy. Remember, we’re using a hand drill here, and working with 2x4 lumber that has a 1/4" round over on the edges and random wild grain to drill through. How are these linkages affected by being mounted off-center?
I’m just saying that the process has several points where accuracy can be compromised, and no provision for verifying or adjusting it. All the linkages need refinement before any one is ready to become a standard.
All true to some degree, but I’ll claim that this is all irrelevant.
The linkage kits aren’t competing against some perfect option, they are
competing against the stock maslow, with even more holes to drill, and more
things to measure, all of which result in much less predictable errors when you
get it wrong.
If you mount a top linkage wrong (assuming you get the distance between the
holes on the standoff right), you end up with a slight offset and pendulum
effect. This is a minor source of errors compared to building a traditional
chain mounting.
I think it’s easier to make mistakes assembling the 45 linkage kit (gluing parts
together adds additional room for errors, and with four standoffs instead of
two, there’s more chances for doing things wrong)
But it’s still FAR easier to get the wrong value for one of the many variables
in a stock design (let alone the problem of getting the precise geometric
relationship of the chain mounts, bit, and center of gravity)
“In theory, there is no difference between theory and practice. But, in practice, there is.”
The pendulum effect means ovals instead of circles, tabs that don’t fit slots, corners that aren’t square. No automatic calibration will correct that.
The calibration routine has become good enough to achieve the target accuracy over a reasonably large portion of the build area, and that area increases with refinement. Triangular Kinematics is simpler, but in the current forms physically harder to implement.
The circular linkage brings something that the current linkage kits lack, a complete mounting arrangement. If it is manufactured accurately, measurements made on the plane of the sled will correctly align the whole unit, independent of the tools available or skill of the user. It looks like installation will be a matter of assembly rather than construction. In this, it takes the next step beyond a ‘proof-of-concept’ device. The chain attachments provided with @pillageTHENburn’s kit is another example of that kind of refinement, making it a simple to use as the ‘traditional’ arrangement.
The triangular Kinematics approach is still developing, the calibration is changing and improving. It’s still ‘beta’, though. Maybe an ‘advanced beta’, not yet v1.0
Going to try to stay on-topic here as opposed to my last attempt to respond to a thread…
While I do think that some form of the linkages should come with the machine, but I agreed with @blurfl that it’s still too early to implement it. I completely agree with @dlang when he says that the linkage is at 90+ out of 100, whereas the stock setup is more like a 30. However, the linkages still need some refinements, such as the mounting pattern, before they are good enough to become the “stock” setup.
I think the mounting issue that’s being discussed can be solved if we provide an SVG of the sled with holes for the risers. That way, once the temporary sled is dialed in “well enough”, the operator can cut out a sled with the needed holes cut relatively accurately. I know from my own experience that letting the machine handle locating the linkages helps greatly.
The other issue we have is that currently there are 3 different versions of triangular kinematics and no clear “best” version. Each have the advantages and drawbacks. I think we need to test each of them head-to-head to see which one would be best for the stock version. I have David’s top-mount setup on my machine, and I’m still having issues getting the level of accuracy I’m looking for across the entire bed. I have @pillageTHENburn’s 45 kit on order and I plan to test the two to see what differences there are between the two. I probably should also get @bar’s ring setup and test that against the linkages. I think it’s crucial to test all three versions on the same machine so that we can get controlled results.
Once we have a comparison between each of them setups, then we can decide which one should make it to the stock version.
then the question is what we would need to do to get to the point of making one
of them the stock setup.
This is one place where I think the 45 kit is behind, it requires more mounts in
precise locations. It’s hard to be precise before you have an accurate machine
to work with (although as I noted earlier, you can drill the holes based on the
linkages)
the top mount kit requires only two holes in the riser, vertically in line with
the bit, so it’s easier to mount
the ring kit can be centered with a printed circle jig (as long as that jig is
not distorted too much when it’s printed)
I would LOVE to see direct comparisons between the different options.
What do we need to do to make this happen? can we do it fast enough to not force
the next batch of users to have to buy something extra or suffer with the stock
kinematics?
I use that quote a lot, but here I will say that things are bad in theory, but
in practice there is not much different between the results of the different
options
it depends on the size of the pendulum effect. The maslow is moving fairly
slowly (and can be run even slower if you want to have it cut a more accurate
set of risers for example), and we are not talking about several inches between
the pivot point and the bit, but rather a few mm if someone is particularly
sloppy.
I disagree that the calibration routine works well enough with the stock
kinematics
so if the top kit had one more pre-made piece that the links connected to at the
center, and attached to a metal bracket, that would satisfy you? It would be
pretty easy to add one more piece that also had a couple holes in it to attach
to brackets like the Z axis uses. I didn’t bother to do that because a 2x4 on
edge seemed ‘good enough’ and saved a few bucks. but it could be done pretty
easily if needed.
not yet v1.0
Not to muddy the waters further by throwing a third option into the fray but the goal is to ship the next batch with the ring as the attachment system. I fully agree that the rotation mechanism is a huge step forwards and I want to get it out there.
I like the ring because it is dead simple to mount. All you need is the included allen wrench and a philips screwdriver to attach it to the sled. A moderate amount of care is needed to keep it centered around the router but a paper template makes that pretty simple.
With the ring included in the kit with an exactly known radius with no room for user installation error the ONLY unknown variable will be the motor spacing which means there will be only ONE variable to adjust in the calibration process which sounds like a total dream
The ring is also simple to adjust vertically. It is also very easy to have a few rings made of a larger size to accommodate the bigger routers out there.
I haven’t announced it yet because I’m still sourcing all the parts so something could go wrong still. We have enough of the old brackets left that if anyone wanted the old system we could easily give them the brackets, but I don’t know why anyone would. The goal is that the next batch will ship with the ring in the box.
Holy damn that’s awesome! I hope that in my previous post it did not sound like I was ruling out the ring approach. It has some possibilities to actually outdo the linkages as far as accuracy. I know that the early versions it skipped as it moved and Logan had mentioned in the triangular kinematics development thread that the linkages work better with the forces available. However, it doesn’t have the same opportunities for compounding errors that the linkages have if there is any play in their connections. I know that is an issue for the top mount, not sure about the 45 degree version.
Which brings me to:
While what we have right now for linkages might actually be perfectly fine, I err on the side of caution. We really need to do more tests and trials to see how well each system works and where they are going to encounter issues. What if we sent out one of the linkage systems with the stock machines and they have a critical flaw with compounding errors or wear? Even if an issue doesn’t come up during regular use, every machine is going to be pushed to the extreme at some point, and that could trigger a bigger problem. I deal with these kind of issues on the shop floor every week when we make a system change and it has unintended consequences. Are we expecting that all these new Maslow operators are now going to have to deal with these problems?
That being said, in erring in favor of caution, this does slow down the development process. The last thing we need is to become a bureaucratic mess and get in our own way. So maybe the correct way to move forward is to ship the ring as is Bar’s goal, AND send out the original brackets so that the operators have the option to to back to quadrilateral if issues do come up. I know you say that using the original kinematics is “suffering”, but I ran my machine for a few months using that setup and it really is good enough to get acceptable results.
I think there is a bit of misconception with the stock kinematics being “inaccurate”. Yes, quadrilateral will begin to distort at the left, right, and top dead center of the machine. But the stock sled is only 18" in diameter. I was able to cut out a sled for the top mount linkages WITH the mounting holes using a stock sled, and the hole placement is exactly where it needed to be. When I checked the hole placement with the linkage arms, in the same manner that you had suggested to locate the holes on an existing sled, it was dead nuts. I think that any operator going through the build process should be able to get the same results.
In my previous post, I had said that the temporary sled could be used to cut the linkage sled. I misspoke there. I do not like the temporary sled. In the brief amount of time I used it, it was unstable, unpredictable, and a pain to use. I would agree with you there in saying that using the temporary sled for any length of time is suffering. I would like to correct my previous statement and instead recommend that the 18" round sled with the stock mounting solution could be used to cut that SVG file. I would edit my previous post, but I think that anyone reading through this thread might loose a bit of context in our discussion.
This would certainly bring it more to the same level of “completion” that Bar’s ring solution has. I still think that an SVG file would be the best way to move forward, but giving the user the ability to easily modify an existing sled. As @Blurfl said, then it becomes more assembly and less construction.
Me too! It’s on my to-do list, along with feedrate tests, a proper z-axis, implementing M codes, and far too many other items. And this is exactly your argument. We are relying on a group of people to do these developments at a hobby level, which means that work, family, health, etc are always going to get in the way and slow the process. Any chance @bar will hire us to do these developments as our 9-5?
Ultimately, however, I do agree with you David. The linkages/ring should be the stock option for the machine. The issue that I, and I believe @blurfl are arguing is how do we go about effectively implementing it in a way that doesn’t negatively affect people coming into this?
what size holes are needed to use the brackets that the Z axis uses? I’m adding
a bar that would use them to the top mount kit
As a placeholder, I’m putting two 1/8" holes 1" apart, both in the vertical bars
and in the new bar (so that you can locate those holes with one of the vertical
bars)
The next issue would be getting that bar straight. I think doing it without the
router in place and just folding the linkage to it’s narrowest point would work
pretty well.
I think the Z axis type holders are going to have enough slop in them that I
would still recommend just using a 2x4, but if that’s deemed too complicated or
something, this will work.
acceptable results.
It all depends on what you call acceptable results? IMHO, fussing about the
possible compounding errors in the linkage kits while ignoring the far more
serious errors that we have no way of accounting for in the original kinematics
is massivly misunderstanding the problem.
moving vertically in the center works well with the quadrilateral kinematics,
but with so many variables that distort things in different ways (and
calibration doesn’t even try to address most of these, it just changes one of
them until it produces ‘good enough’ results in the one location)
I can produce a pdf file that (if printed without distortion) gives you the
right placement of the linkages on a 2x4 pretty easily, I’ll do one tonight.
svg files have the problem of scaling, but it’s pretty trivial to convert from
one vector format to another.
Ok, it was sounding as if you were arguing that because the linkage kits are
‘only’ 90+ on a scale from 1-100 that we are better off shipping a few hundred
more kits that limit people at 30 on that same scale.
If it’s just a matter of trying to improve the existing kits, fine, let’s work
on improving them.
Here is a vector sled drilling template (which also has a scale to check for distortion/accuracy) and here is an SVG of the same file.
I feel like adding much of my opinion to this thread could end up being a “too many cooks in the kitchen” scenario, so I’ll mostly hold off for now.
Except for this:
I agree completely and I REALLY want to see that happen! (btw, @MeticulousMaynard your kit will be in the mail shortly!) I feel like Bryan is the right guy for the job too; I’ve witnessed fantastic data collection on his part. I know it appears that the ring will be the best choice to ship (and I’m not arguing there) but I’d still love to see a comparison just for curiosity’s sake! Data is one thing but ease of use is also important.
I even have hypotheses about the results! But I can save that for another time
-Logan
The riser arrangement needs to provide stability in the X and Y directions. Also give some thought to a quick-release for the chains. The other two linkages provide this, and it’s necessary, not just desirable.
We all will. We should start a list of measurements and observations for the testing. Volunteer?
Adjustability means the system is going to have to be more complicated to have the same stability as a static one. I think that the template is at least the easier route to go for now.
I like that a lot. I have had to take my sled on and off the chains a lot as I’ve been getting things dialed in, so having that link would help speed up the process significantly. I’ve had to spend quite a bit of time looking for the master link parts when I either dropped them or they flew off when I released them. Entirely my own fault for not being careful enough.
I think I inadvertently did when I mentioned I was already planning on testing the two linkage systems together. I’m fine with that, but it will take time for me to do it right. The other thing that that my machine is smaller than the stock version, so results will be more extreme at the far sides of the bed. It may be a good idea to have a couple of people try this, especially with all the frame variants that are being made. I would be curious to see how much that also plays a role in the accuracy we see across the bed.
What do we want to see in the tests? Would something like I covered in this thread be good? I checked to see how well accuracy in a small shape in regular intervals across the bed. If I’m missing something crucial, though, we can work out a good test for it. I know I would like to have some way to measure compounding errors (aka slop) for each version. Should I also test the stock kinematics so that we have a control?
@Bar, I should probably go ahead an order one of your ring setups as well
Admittedly, part of my hesitation about adding this as part of the stock package is that I am still working out the issues with my own setup. My observations so far could be based in my own poor hardware choices. Or I haven’t dialed in the calibration as much as I think I have. I would absolutely LOVE to be wrong here, because then I would have more time for making cool stuff
